996 Forum 1999-2005
Painted rims...what to do about lug bolts
Old 12-09-2013, 09:09 AM
nymart
nymart's Avatar
Default Painted rims...what to do about lug bolts
So since I pulled the bacl wheels off to do the coils, I decided to pull all four wheels and Plastidip my rims. I'll post pics when they are done. Went with Anthracite Grey Metallic with a little gloss. So far I'm really happy with the results and I think it will go well with the blue and make the car a little more "mean" looking. But what to do about the lug bolts. I've searched all over the net and the only thing I can find are the standard, black or chrome. I don't think any of those will look good. I can just Plastidip the bolt heads to match but I assume that it will just rip off when I try to put them back on. Any suggestions?
Old 12-09-2013, 09:46 AM
Sneaky Pete
Sneaky Pete's Avatar
Go to a Auto Parts place and find some spray paint that matches. Clean the lugs up, get some cardboard and poke 20 holes in it to put your lugs through. That way you only paint the heads and not the threads. But all said and done black would look fine.
Old 12-09-2013, 03:37 PM
Mark I
Mark I's Avatar
What Pete said...you can also use a socket with an insert to help preserve the paint.
Old 12-09-2013, 04:01 PM
nymart
nymart's Avatar
I saw a socket with an insert, but it said NOT to be used on stock steel lugs...only to be used on Aluminum lugs...is there another type that someone can recommend?
Old 12-10-2013, 11:28 AM
onewhippedpuppy
onewhippedpuppy's Avatar
This. $5 and a few coats and you'll be done. To preserve your bolt heads and the wheels go buy a set of "soft sockets". You can find them at most tool stores, at least those that sell auto related tools. I think mine are from good old Harbor Freight.
If you want to be really fancy you can get a set of bolt covers, though they have to be removed before you can remove the lug bolt. http://otisincla.com/index.php?route...egory&path=223
Old 12-10-2013, 11:38 AM
nymart
nymart's Avatar
Thanks onewhipped...I actually did order a set of grey bolt covers...I'm just not sure how well they really stay on. I figured I'll see how well the grey matches the color of the rims and if it's too far off, I'll plastidip the covers so they match. And since I practically live at Harbor Freight for tools that I only use on occassion, I'll be sure to look for the soft sockets next time I'm there.
Old 12-10-2013, 01:32 PM
Neb
Neb's Avatar
I dipped the bolts too, as suggested above. Just stick them in a box with 20 holes and spray away.
Old 12-10-2013, 02:24 PM
nymart
nymart's Avatar
Neb...any issues with it scratching off during install?
Old 12-11-2013, 09:34 AM
Neb
Neb's Avatar
You have to be more careful putting socket on and off. Still use the same Socket size. I did 5-6 coats. And I hand torque then use torque wrench. No peeling.
Old 12-11-2013, 03:53 PM
pesuazo
pesuazo's Avatar
I bought and installed the bolt covers.......
Old 12-12-2013, 05:47 PM
onewhippedpuppy
My old 2001 came with beautiful black powdercoated '02 lightweight wheels and the black bolt head covers from Otis. They snapped on pretty positively and had a nice little tool for removal, I don't think they would fall off. My only complaint was having to snap them off before pulling the bolts, but it's a minor nuisance.
Old 12-12-2013, 06:08 PM
alpine003
alpine003's Avatar
If you want a long term solution and not have to be delicate or touch up wheel bolts everytime, I would look into getting them blasted and powder coated. A couple places around me charge under $50 for this service.
Old 12-12-2013, 09:30 PM
nymart
nymart's Avatar
thanks for the suggestions guys!!
Old 12-13-2013, 09:20 AM
Ubermensch
Ubermensch's Avatar
Does powder coat hold up to removal and installation?
Old 12-13-2013, 11:26 AM
Revn29k00
Revn29k00's Avatar
Will the socket still fit over the lug after powder coating? You could always leave the lugs chrome. I think it would be a nice contrast but it's obviously personal preference
Quick Reply: Painted rims...what to do about lug bolts
