996 4S Front Diff Rebuild
Hi,
Appreciate this is an old thread but I replaced by diff side bearings and still have some noise (which disappears momentarily on lift off). I removed the cardan shaft and the noise completely disappeared on power but then was worse on lift off. I'm thinking it may be the pinion shaft bearings? I inspected the best I could without tearing apart but couldn't get enough torque to take the pinion nut off. I put it back together knowing at least it wasn't about to explode but I would like to get rid of the noise. Did you make up some sort of fixture to take the pinion shaft nut off which locks the output flanges? Any advice would be great!
Thanks,
Rich
Thanks,
Rich
I'm in the process of tearing down my front diff. from a MY 03 996 TT in order to rebuild it. Can anyone comment on how the pinion nut was removed as well as a part list for rebuilding the unit? Any advice would be very much appreciated!
Best Regards,
Tim
Best Regards,
Tim
Hi,
I know, this is an old thread, but this includes my problem. Thus, I give a try and hope someone, who did the rebuild, reads this and can support me!
I need to reassemble the side bearing cover and the housing (these two parts)
My concern is to correctly push the bearing (foreground) into the housing (backgroung) without damaging the housing!
Can I simply do this tightening the 8 screws connecting the cover with the housing or do I need a special "pressing" tool for this??
Any help is very welcome !!
Marco
Marco
Hi,
My concern is to correctly push the bearing (foreground) into the housing (background) without damaging the housing!
Can I simply do this tightening the 8 screws connecting the cover and the housing or do I need a special "pressing" tool for this??
Thanks and greetings from Germany!
Marco
Marco
Marco-
If the same component is going back in the transmission that was taken out, there should be no issues. I assume you changed the bearing? There was most likely some very thin shims behind it to properly space it to the casing, but don't know for sure as it is a single row, deep groove ball bearing.
The outside diameter of the bearing is a clearance fit to the inside diameter of the housing, and if it's the same component group that came out with exception of the bearing, it should be no issue.
I would think there would be NO pre-load on that bearing, but an axial clearance to the housing. So just install and tighten away. If it binds up before the flange bottoms out, then something isn't right.
Good luck! Ciao!
Good luck! Ciao!
Hi,
and thanks for the reply!
You are right, the bearing was changed, but there were no shims!
When I put the cover with the assembly back on the housing, there is a resistance
between the bearing and the housing! That made me feel, that it needs to be pressed in somehow! I can not just push it in by hand!!
Use bolts of the housing to press it back in. But go evenly by tightening the bolts on opposite sides (like you would install a wheel.) Tighten them in stages; first time around half way, second 3/4, third seat, fourth torque to spec. This will press the housing back in evenly.
As with any press fit bearing, putting it in the freezer overnight before the install, will make it go in much easier
Additionally, clean the housing where the bearing sits very well with some brake cleaner and scotch bright pad or something of the sort. This will polish it and remove any high spots. Clean it very well after this before installation.
Thank you for all the replies!
I will put it in the freezer then and tighten it like @white out described! Cleaning of course is a must!
Does anybody know the torques?
Should I apply any sealant between cover and housing?
Thanks again!
Thanks again!
Do yourself a favor and get this book:
http://www.theknowledgegruppe.com/in...96-automobile/
You'll wind up using it every time you work on your car...
