You said you glued yours? how long did that last for? Is there any temporary solutions, I am thinking of upgrading to Turbo next year so don't want to be spending too much money on this one.
I used the "6000" glue from Michaels. The have a UV-6800 glue that may be better.
Once the glue sets, it lasts for years. I fixed a corner two years ago and haven't had any problems with that part of the top. Make sure you glue it, clamp it for 48 hrs. I used two pieces of wood and a large C clamp to hold it while it cured.
What is the friss fix? My top window just seperated today. there is big gap at the bottom left corner, I have a feeling by tomorrow morning it will be full length wise.
I believe he was referring to my DIY from a few years ago. I did a combination glue and sew repair job on my window in 2010. Three years later, it's still holding up great. The only thing I would skip is the use of the silicone caulk to waterproof the seam. Just use a heavy application of Raggtop or Porsche convertible top waterproofing spray on the seam instead.
