Underdrive Pulley Kits and Tow Hooks in Stock
Captain Obvious
Super User
Super User
6hp at what point in the graph? But regrdless you will not feel a 6hp gain on a 300hp car. There is at least that much variation on the dyno depending how tight the straps are. Sure there will be some gain with an underdrive pulley, the question is, is it statistically significan and more importantly, can you feel the improvement. If you can't feel it, what's the point on a street car.
On our 3.4L Cayman one of the other side benefits was it helped reduce the power steering overheating issues at the track too.
A small battry and an underdrive pulley is about the worst combination for a street car. 16hp or even just 8hp is a massive amount of power. There is no way an underdrive can pull this much away from the acessories. Just think about it. You push lawnmower is 3.5hp a riding one is under 16hp. Even if you reduce the acessory speed by 50%, there is no way you can save that much power. Now if you want to reduce the accesory speed at redline to make it last longer (under racing conditions) then an enderdrive pulley makes sense but to make 16 or even 8 hp is just nonsense.
Your accessories rob ~25hp (10hp power steering, 10hp+ AC compressor, 5hp alternator). Your power steering pump has to put the fluid @ 400+ PSI, you can't compare that with a push lawn mower.
The underdrive pulley reduces the accessory speed by 20%. With the mad assumption that the hp loss is linear with the rotation speed of the accessories (certainly not exactly true), then you gain 5hp.
Bottom line, I have one on my car and I clearly felt it. If you want to call it placebo, fine, that was still only $200.
The underdrive pulley will probably save some power on the power steering pump (you get less steering boost) but for A/C and alternator, I doubt there's any saving. If the A/C compressor spins slower, it has to spin longer to achieve the same cooling. Same for the alternator, if it spins slower, more current needs to pump into the rotor to maintain the same power output, which requires more force to spin.
A/C compressor and alternator require fixed power at any point in time (depending of what appliances are turned on, and the cabin temp settting, etc.) so regardless of pulley size, they will rob same power from the engine.
Super User , we use a DYNO PAK dyno, each rear hub is bolted to the rear drive hubs of the dyno, there is no slippage. We came up with the underdrive pulley to reduce the power steering assit , heat from excessive pumping which not needed at constant high rpms when "racing". 6 hp is a safe increase for little money. The Cayman is raced at 4000 to redline. Reducing the water pump speed allows the water to pick up a bit more heat as the speed of the slowing coolant has time to pick heat. In racing small things add up.
