Underdrive Pulley Kits and Tow Hooks in Stock
Premium Sponsor
We are now stocking underdrive pulley kits from RSS for the 996 and 997 NA cars (pre-2009). These are made from 6061-T6 aluminum and offer improved HP & TQ by reducing drag from the power steering pump, A/C, water pump and alternator.
On a modified 997S (with headers/mufflers/cats), the power gains were +16 HP / +8 ft lbs TQ, and I would expect similar gains on a stock car:
The standard pulley fits 3.4L and 3.6L applications, and can be ordered directly from our web site here:
http://www.sharkwerks.com/products.php?pid=400
3.8L 997S require a slightly different (dampened pulley):
http://www.sharkwerks.com/products.php?pid=401
These re-use the existing belt. Here is the installation document from RSS:
We are also stocking most RSS parts now including these high quality Tow Hooks:
Perfect for a track day!
These can be ordered here:
http://www.sharkwerks.com/products.php?pid=399
Dan Kennedy
SharkWerks: www.sharkwerks.com
Northern California's Porsche Performance, & authorized Evolution Motorsports, TechArt, HRE and Tubi, Cargraphic dealer and installation center
Phone: 510-651-0300
Email: dan@sharkwerks.com
SharkWerks' Latest Updates on Twitter
Dan Kennedy
Phone: 510-651-0300
The UD pulley was the last mod I installed on my 986 and the first thing I ordered for my 996. I approve.
...and the install on the 996 is way easier than on the Boxster.
Apparently because race car. Incidentally a week after I ironically spray painted the tow loop on my Range Rover bright red for the aforementioned reason, said loop was used to pull it onto a 10ton flatbed with airbrakes when the rear diff shot a bolt through its case. Karma I guess.
Off hand since I'm at work, are the factory 3.4 and 3.6 pulley's dampened?
I'd like to hear your first hand experience on your 996 on whether you noticed a butt dyno difference of power, or if you think it's merely throttle response improvement. Any noticeable effects on A/C cooling?
I have the tarett engineering on mine, definitely butt dyno approved.
I live in Texas and both engine cooling and AC do just fine even in stop and go traffic.
Only difference I have noted is that I don't seem to get quite enough juice from the alternator at idle. Once RPMs are up then it stabilizes ~13V. Not a big issue for me since I have a mini battery, so not much to recharge.
Captain Obvious
Super User
Super User
no, on the 996 the factory pulleys are not dampened.
Premium Sponsor
Sorry for posting up another manufacturer's dyno, I think these numbers are from an optimstic case (a 3.8L car that's already been modified). On our own 2006 Cayman S 3.4L engine we picked up some power on Evolution Motorsports' mustang dyno, I think this dyno sheet is MIA now but I'll look for it. There are also several race teams that have used these pulley kits. RSS does not have a dyno in-house so I guess it would be an independent dyno, however I was not there and cannot verify the test process or if they followed what we would typically do for a dyno tune (which is 10+ pulls until the numbers settle at a consistent peak number, then tune and repeat the ~10 pulls). If we had a test car and dyno here, I would test their product myself.
I think the factory alternator generates around 130 amp, 13.8v = 1794 watt = 2.4 horsepower (so it takes more than that to turn). Maybe someone can confirm.. Not sure about A/C, water pump, power steering or which items would clutch at WOT (A/C would probably decouple at WOT, but the others would remain mechanically connected). I think it's a fair assumption that between all the accessories, there is at least 10-15 HP being drawn from the engine, if not 20+. If this pulley underdrives by 15%, that would be just 1-3 HP.
I do not know the pulley size ratio or the actual accessory numbers, so I can't say for sure what the power would gain. But I would bet 100% of my money that it will gain *something*, and on these cars that's hard to do. Let's say it's just 2 HP. At a price of $179 if you DIY, that's actually a better return on your investment than many mods that might actually cost you power (hot air intakes, unresearched headers etc.) and it's up to you to decide if it's worth it. Another benefit of underdriving accessories is better throttle/engine response which can't really be measured on a dyno.
While not a "new" idea to the industry I think especially for modded and/or track cars it's traditionally always been a neat and cost-effective idea of gaining a few ponies. As a side benefit on the Cayman we were able to somewhat reduce the stress on the power steering system at the track (1st gen caymans were notorious for having power steering issues).
We change pulleys on all GT3 engine upgrade cars we do here, and even the factory does this for the RS models which further helps throttle response.
