Brake wear sensor removal - how?
How do you unhook the brake wear sensor wire from the caliper. I can't see how it unhooks and I don't want to break it.
Received 5,411 Likes
Hard not to break. Always best to order new sets when doing pad replacements. About $39/set.
You can also bypass, and just zip tie back.
I used a small blade screwdriver and pried it up from the bottom. Don't pull on the wires as it wouldn't take much to damage them.
If you're tracking it, just use a zip tie and secure it out of the way.
Thanks. Got it.
+1 on zip-tying it to one of the hard lines so it's out of the way. If you're a DIYer, I can't imagine the only time you know how much brake material left is when the sensor gets wrecked...
If my sensors are still not worn out, can I cut the wire 3 inches from the shock tower plug, and solder them together - removing them from the system, without a warning light?
I did this, but haven't soldered them (couldn't find my soldering gun when I did it so I just used electrical tape). Occasionally on the track, the brake sensor light will come on intermittently, and it is very annoying to have a new red light pop up when you are on the track. Next time I'm in there, I will solder them as you suggest.
