Blackstone Oil Analysis
#213
Forgot to cross-post here from my other thread. Not sure why my silicone is on the higher side. It was an 8 at the last oil change in August and I promptly changed the air filter in response to it. ALS claims this is within spec, though.
Latest update with 83,454 miles on her. 3894 miles and 7 months on the oil.
"All wear rates normal. Abrasive and other contaminant
levels are acceptable. Viscosity within specified
operating range."
Metals (ppm)
Iron (Fe) 4
Chromium (Cr) <1
Lead (Pb) <1
Copper (Cu) 3
Tin (Sn) <1
Aluminium (Al) 3
Nickel (Ni) <1
Silver (Ag) <1
Titanium (Ti) <1
Vanadium (V) <1
Contaminants (ppm)
Silicon (Si) 10
Sodium (Na) 6
Potassium (K) <1
Additives (ppm)
Magnesium (Mg) 11
Calcium (Ca) 2585
Barium (Ba) <1
Phosphorus (P) 1058
Zinc (Zn) 1248
Molybdenum (Mo) 109
Boron (B) 22
Contaminants
Water (%) <0.05
Coolant No
Physical Tests
Viscosity (cSt 100C) 12.6
Physical / Chemical
Base Number (mgKOH/g) 6.5
operating range."
Metals (ppm)
Iron (Fe) 4
Chromium (Cr) <1
Lead (Pb) <1
Copper (Cu) 3
Tin (Sn) <1
Aluminium (Al) 3
Nickel (Ni) <1
Silver (Ag) <1
Titanium (Ti) <1
Vanadium (V) <1
Contaminants (ppm)
Silicon (Si) 10
Sodium (Na) 6
Potassium (K) <1
Additives (ppm)
Magnesium (Mg) 11
Calcium (Ca) 2585
Barium (Ba) <1
Phosphorus (P) 1058
Zinc (Zn) 1248
Molybdenum (Mo) 109
Boron (B) 22
Contaminants
Water (%) <0.05
Coolant No
Physical Tests
Physical / Chemical
I know this is a Blackstone thread, but I've been very happy with ALS. I get their test kit at O'Reilly's for about $20. It is actually labeled as a Wix kit, but the paperwork inside contains the address and info for ALS. They also provide TBN results at no additional charge. TIFWIW.
#214
Since this thread was brought back to life, thought I would share my reports. I am always curious on how others stack up so figured others were also. Note the following:
1st sample on 9/13/17 is when I switched from Mobil 1 to DT40 (no, I did not due a complete flush)
2nd sample on 11/11/17 at only 500 miles was pulled through dipstick (I wanted more of a control sample of the DT40)
3rd and 4th samples were normal oil changes (still DT40), I drove 3500 miles on 4th sample to be more in line with the universal averages. I typically change at 3000 miles.
I always make a day of changing my oil checking other fluids, crankcase pressure check (for AOS, typ 4.5 - 4.9 in WC), tires, brakes, ect.. I dropped the sump pan during the 1st 9/13/17 (just to inspect) and installed a magnetic plug at that time. Still have OEM filter, find it easier to cut open and check filter. I also empty the oil filter into a clear glass jar to inspect oil within filter and use an endoscope through drain plug hole to check inside of sump. (guess I'm a bit ****)
#215
Here is mine....
Interesting on the concern for an air filtration leak. I am using a BMC filter with the old style Fabspeed exhaust and intake (with the stock filter box).
Installed LN filter conversion using NAPA filter at the previous oil change. Cut open filter and could not find any junk.
#217
You have to remember the mileage that you put on the oil. The particle count is going to be proportional to it, the longer the oil is in service, the higher the particle count.
My copper always seems to be a little bit higher than others, it's closer to 7 or 8 PPM. Others are closer to 3 o 4....but once again, you have to take into account the miles on the oil.
With your mileage I personally wouldn't worry about a thing....nothing seems to jump out at me....I'm no expert, but I do look at copper a lot.
#218
#219
In my humble (and very non-scientific) opinion, it appears that you’re trending in the wrong direction. But it’s also really hard to capture what “normal” is for your engine with only two analyses. You may find out that theses values plateau and remain approximately the same for every subsequent analysis.
#220
Here is mine....
#221
Did Blackstone provide a descriptive analysis? If not, you should reach out to them to get their opinion.
" The metals are low and look great compared to universal averages and the previous report. You didn't see any visible metal in the filter and that's another good sign that all is well mechanically. There's no fuel or moisture present and the air and oil filters kept silicon and insolubles low. Excellent report."
#222
the report was good:
#223
When you see elevated manganese due to valve guide wear, approximately what PPM of material are we talking? 10/100/1000? Asking for a friend... 9A1 3.8 991 C2S. No octane boosters used. All other wear metals look good, 1.5% fuel dilution
