Aux input on CDR 220
I have installed an AUX cable to my C2 2002 but I am having trouble to make the final settings. I have navigation so I guess that means that I have a Becker CDR 220. I have read on several places that I am supposed to press the TP button for about 10 seconds to get access to a menu in the stereo and then enable the AUX input. The problem is that I cannot find any TP button on my stereo...
Anybody got a qlue?
Robert
Anybody got a qlue?
Robert
No
I got:
CC CD (cassette or CD)
FM AM
1-2
3-4
5-6
Left arrow-right arrow
Main
Audio
Tel
Navi
BC
AC
"A phone" button
Repeat
dark
map
And then the two **** for volume and selection
Robert
I got:
FM AM
1-2
3-4
5-6
Main
Audio
Tel
Navi
BC
AC
"A phone" button
Repeat
dark
map
Robert
First, try pushing the source select button a few times to be sure it's not already enabled. The menu should cycle between FM, CD, and Aux. As I recall source select is on the top right. If Aux is not displayed then hold the TP button until "BECKER1" is displayed. Rotate the right hand **** thru the various options until you get to "Aux Off". Now, this part I don't quite remember but it should be easy ... either push the **** or whichever station button on the bottom has arrows on it. This will toggle the display to "Aux On". By now you are probably comfortable with the menus. If not, just cycle the power (so you don't mess anything up on the way out.) Congratulations, your finished.
Hrm, after reading your second post (which you posted while I was typing) ... you don't have a CDR-220 dude. You have a PSM1 system. My sympathies
Just kidding. Your all set, just set source to "CD"
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
went here to find your answer:
PORSCHE NavTraffic Pro RADIOS
1. Press the "Radio" button to enter Radio mode.
2. Press the "Nav" and "F10" simultaneously
3. Press "Next" until the AUX input, Changer Res screen
4. Press AUX to enable/disable.
maybe that works?
maybe that works?
Robert
maybe that works?
maybe that works?
Robert
Ok, I bought this one:
http://www.ebay.co.uk/itm/BECKER-VDO...item231ba3eef9
and I plugged it into the stereo by replacing the blue connector in the big connector consisting of a yellow, a green and a blue connector put together as one big connector. You can see the connector on the picture here: http://www.discountcarstereo.com/3.5-BKRCD.html
Any thoughts?
Robert
Any thoughts?
Robert
I just read the instructions here: http://www.discountcarstereo.com/pdf/ip-bkrcd.pdf
I didn't buy this specific kit, but at the bottom of the document it reads:
1. The iP-BKRCD is compatible with Porsche non-AUX MODE Radios (i.e.
CDR-210, CR-210, PCM1 etc.) with A WORKING CD CHANGER.
2. Requires a working CD Changer (i.e. CDC-3). The changer will no longer
play but must remain connected in order for the radio to enter “CD
CHANGER” Mode. At least one DISC must remain in Changer
Magazine and must be selected whenever iPod playback is
wanted.
They say that the CD changer MUST remain connected... I have removed mine since I am not using it anyway... Maybe that is the problem? But I have read that other people without CD changer have installed an aux cable.
Robert
wanted.
Robert
