996 Forum 1999-2005
cd changer not found
Old Apr 17, 2013 | 08:06 PM
jwex16's Avatar
jwex16
Default cd changer not found
I just got an 04 TT with a stock navi setup. when I select the cd changer I get the error message "no cd changer". I have inserted a couple cds, checked connections and still same message. The cd changer was dealer installed after initial delivery. Obviously the battery has been replaced a few times. Is there any trick to having the head unit link to the changer? I did something before on my old unit in my '02 when I set up the aux input. any ideas?
As long as i am at it, is there a plug to connect my iphone as an mp3 player?
I really do not want to upgrade anything, I just want what I have to work.
Photos are coming when i can figure out how to upload to rennlist from my ipad.
Old Apr 17, 2013 | 08:23 PM
thedugger1's Avatar
thedugger1
Just for the heck of it, disconnect all the connections at the cd changer, wait a minute or so and then reconnect. That has worked to "reset" mine in the past when I've had a similar issue.
Old Apr 17, 2013 | 08:24 PM
thedugger1's Avatar
thedugger1
P.S. what area in Philly are you around? I'm out of Lower Merion.
Old Apr 17, 2013 | 08:30 PM
jwex16's Avatar
jwex16
drexel hill
Old Apr 17, 2013 | 10:21 PM
frisbee91's Avatar
frisbee91
You can replace the cd changer input on the back of the head unit with an iPod cable. I think Becker makes one, maybe on eBay too.
Old Apr 17, 2013 | 11:00 PM
thedugger1's Avatar
thedugger1
I'll keep my eye out for you! I'm in Havertown all the time. As for the aux hookup, do a quick search here, I bought the cable from amazon for $15, took 2 minutes to install since I had the stereo removal tool. You do lose your cd changer capability however.
Old Apr 18, 2013 | 09:57 PM
jwex16's Avatar
jwex16
Default Fixed-bad battery
Well it was a bad battery. It was even under warranty. Less than 2 years old. You never know
Old Apr 19, 2013 | 11:23 AM
rpm's S2's Avatar
rpm's S2
My BMW X3 forgot it had an AUX function. It took a full software reflash to recover.
