Coolant Expansion Tank Labor Hours
Depends on the year. It took me about an hour of contortions to remove it the first time, about a half hour to replace it. After my plastic weld job, it started leaking again several days later. This was on my '99 Cab.
I changed the tank on my 99 coupe last month. Took off airbox, disconnected rubber pipes and disconnected 2 fuel lines, disconnect temp sensor. Removed tank Took less than 30 mins. Installing new tank and reconnecting took 15 mins or so. I have never done it before so an hour should be easily achievable
Thanks for the input but I am looking for someone with the actual book labor hrs. This was on an '01 C2. The shop initially told me 1.25 hrs then charged me 3.5 because I needed the car the next day.
