On Board Computer (OBC) Hack and custom buttons
#47
I put mine in 2 years ago but never got around to wiring it
. Something else seems to come up that needs more attention. I was planning on doing this in the spring but had 3 months of convertible top hassles.
#49
https://rennlist.com/forums/996-foru...m-buttons.html
http://www.pelicanparts.com/techarti...ox_obd_mod.htm
http://www.renntech.org/forums/topic...retro-install/
http://www.renntech.org/forums/topic...996/?hl=Yoseif
http://www.renntech.org/forums/topic...s-or-question/
http://forums.pelicanparts.com/boxst...-question.html
http://www.pelicanparts.com/techarti...BC_upgrade.htm
#50
I make a custom harness with the correct pins for the factory instrument connector.Hand crimped and soldered and wrapped to look like OEM factory. I have two versions , one for a stalk if you go that route and the other to use a simple switch (window or any other switch)
$45 shipped for the stalk version , $30 for the Dash Switch version. The stalk version has the correct OEM plug for the stalk...when you are done it will look factory to a Porsche dealer
Dwight
fmjbt@comcast.net
Dwight
fmjbt@comcast.net
I purchased one of his harnesses, for a coule bucks more than you can build one for yourself, it's well worth the price paid, top notch quality
#51
I make these by hand in my shop, one dealer actually bought one and then order 4 more to install in cars. He asked me where I got the Porsche wiring harnesses....I try to make them as close to OEM as possible
Dwight
Dwight
#52
Anyone who orders one from you will see your work speaks for itself. It looks every bit of factory, thx again. I should say I am more than capable of making one myself, however I lack the time to head to various dealers to assemble the parts, it was a no brainer to order from you, and I'm glad I did.
#55
According to this DLR cannot be activated by OBC it needs a relay:
https://www.renntech.org/forums/topi...ts-on-us-spec/
Think I mentioned this to you in a previous thread.
#56
There are limited features that can be turned on (that the car has) and also that Durametric can code.
