Seat Cover Issue
Hello All!
I’m looking for a bit of help in trying to fix an issue with the driver’s side sport seat in our ’02 C2. I had a big friend sit in the car, and in doing so he pulled the leather seat cover out of the channel at the edge of the hard shell seatback. I’ve tried to no avail to tug and tuck the seat cover back into the channel, but it doesn’t want to stay put. There appear to be some tiny metal clips along the edge of the seat cover that hold it in place. I’m not sure if mine are now bent or if a few fell off for they no longer want to hold.
I called a local upholstery shop that specializes in repair to automotive leather. They said they can fix it but that I need to get new clips from Porsche. Unfortunately, calling the local Porsche dealer proved to be fruitless as the parts guy had no idea what I was talking about. To that end, I downloaded a version of PET and tried to find a part number for the clips, but it doesn’t seem like they are shown anywhere in there.
Has anyone else encountered this, and/or does anyone know the part number for the metal clips? This happened about 2mos ago, and in the interim the seat cover has worn some of the coating off the seatback (as evident in the picks). I’m not overly concerned about that as you can’t see it when the seat is positioned normally, but I’d also like to get it fixed before it gets worse. Any ideas/thoughts are appreciated!
This.
But if not, contact Suncoast Porsche, their people are great and will spend the time making sure you get the exact part you need. Plus, they usually sell their parts at a solid discount compared to other dealerships.
Cheers,
DS
This.
Cheers,
DS
The Seat is the sport seat in a 2003 Carrera 4S. I changed out the hard plastic shell on the back along with the foam on the inside of the seat. I have clipped the leather into the center of the plastic shell. Now I am trying to reattach the leather along the rim of the plastic shell. It uses a small metal clip that folds over the plastic lip and pushes into the seam. I need a couple more metal clips and can't find them. I called Sonnen and AutoAtlanta, with no luck. Any clue what the part# is for reattaching the leather upholstery to the rim of the outer plastic sport seat?
Any help would be appreciated. Thank you.
I'll post if I find a part #.
Someone previously posted a step by step pictorial guide for taking apart the top portion of the seat. I'll try and find it for you. Last thing you want to do is break any of the tabs on the back hard shell because replacing it is a quick $350-450 you probably don't want to spend.
Byprodriver,
Sorry for the delayed response. Check out these two posts:
http://www.renntech.org/forums/index...m-sport-seats/
https://rennlist.com/forums/porsche-...placement.html
I ended up getting my clip issue solved by taking the seat to a vehicle upholstery place. The guy there ordered 3 different types of clips before he came up with the right one. I would have preferred to do the work myself but it didn't appear anyone on the forum site knew where to get the clips (or atleast didn't send a response). I called 5 different places and asked about the clips with no luck. Like you, I'm ready to just fix the seat and drive the car for the summer. All good to go now.
