Ugh--now the clutch
Weathergirl
Ugh--now the clutch
Well, I tempted Murphy with this post: https://rennlist.com/forums/996-foru...ml#post9977622 and now he's getting revenge.
Yesterday driving to work I first noticed the clutch takeup felt a little weird on an uphill start. Then the pedal got harder and the engagement got lower and lower and I limped in to work. I thought I might be able to drive it to the shop but when I restarted the clutch wouldn't disengage enough to get into any gear. So my second flatbed ride in three months.
They checked the hydraulics and everything was fine, so they're pulling it apart today. Definitely going to do Jake's IMS replacement while they're in there, anyway.
Weathergirl
It was a cracked pressure plate. 71k miles. The dual-mass flywheel is at the limit and needs to be replaced, too.
Good news though--the IMS seal was leaking along with the RMS, so fortunate timing to do all the work.
Was the leak observable externally or you found out only after the trans been removed?
Weathergirl
Sorry, didn't take a photo. The fingers on one side of the failed PP were 1/4" or so lower than on the other side. Normal daily-driver use. No abuse.
However, my shop said that it looked like the clutch had been replaced before. There was a missing plastic spacer and spring clip and rtv sealant around the RMS seal.
