Alumalook Spray Paint
I have been on the hunt for awhile for some alumalook paint to match my interior trim for my non-smokes ashtray conversion. I found this Testors diamond dust #1830. It appears to be a perfect match. I though I would pass along in case others were looking.
Beth02CarreraC2 (09-09-2019)
Thanks! I bought an unpainted console last year and tried to paint it like the trim, but it wasn't even close. I never installed it. I will give this a try.
Yours came out great. Did you clear coat it?
Bill I did clear coat it.
Djantlive the reason I didn't go that route was the cost. I only needed to do one small piece and I didn't want to spend $100+ on paint for $35 accessory.
Thanks! Testor's is available at most hobby shops, too, if you can still find one. I've been experimenting with aluminum look, and tried Diamond Dust, but maybe I'll try it again.
A while back, I ended up buying some Testors "diamond dust" at Michaels, and some Dupli Color Perfect Match BGM0340 Silver Metallic (from AutoZone or Pep Boys).
I painted a sample swatch half with the Diamond Dust, half with the BGM0340, and compared it to the existing "alumallook" parts in my 996.
The diamond dust was a slightly better color match, but it had too much metallic flake in it compared to the stock parts.
The BGM0340 was a better match for the metallic flake.
I went with the BGM0340 for the interior parts that I painted. I still have the test swatch somewhere. I can take a picture of it and post it later.
So here are some photos comparing two "Alumalook" type spray paints. Testors Diamond Dust and Dupli Color Perfect Match BGM0340 Silver Metallic.
I'm finding that photographing metallic paint with an iPhone in direct sunlight to be a difficult task. The photos don't really capture the "metallic fleck" aspect of the paint. However, I'm including the pictures and a description to help clarify what I see.
This picture captures the color of the two paints compared to Alumalook in a '99 996. The Diamond Dust is a slightly darker silver, which matches the Alumalook well. What you don't see in this picture is the fact that the Diamond Dust is more "sparkly" than the Alumalook.:
Maybe you can see the "sparkly" aspect of the Diamond Dust in this photo:
Another shot that shows the color:
My preference was for the close color match of the Duplicolor BGM0340, avoiding the overly-metallic Diamond Dust. Either would work well.
peterp (11-03-2023)
