996 Forum 1999-2005
Sudden RMS leaking/weeping ... I think.. :(
Old 01-24-2013, 10:32 PM
  #31
ivangene
Parts Specialist
ivangene's Avatar
Originally Posted by rpm's S2
I was once at a dealer tech session where we put a brand new Cayman on the rack and it had an oil leak. The tech joked this was 'factory exterior rustproofing.'
HA- THE NERVE!
old schoolers say if its not leaking oil, add oil - you're out!
Old 01-25-2013, 12:01 PM
  #32
AndyK
AndyK's Avatar
Originally Posted by ivangene
I suggest driving it
my 996 used to drop a few drips once in a while...but driving it would "seal" it back up and it wouldn't drip
either that or it will get worse and be easier to find.....wipe the floor clean and if it becomes a daily habit of dripping - go in and fix the drip....you might be surprised to find it only drips 1-2 days out of a month and isnt a emergency
just a thought
PS I never did fix my RMS but did change the AOS and cam solenoid seals and a few other small items - but the rms weeped for sure...just not much, and not everyday
Great advice! My RMS tends to "weep" when the car sits for a while. Driving it cures it!
Old 01-25-2013, 12:49 PM
  #33
darbo
darbo's Avatar
I am new to Rennlist and recently bought an 04 996 with 26k miles. I had done my research and decided to buy the IMS Guardian. When I received it I noticed two things that made me decide to return it. One, the plug does not sit flush with the pan and ANY debris on the road could potentially knock it off and the rest is history. Two, my mechanic warned me that it will buzz incessantly so you will never really know if you are in trouble. Has anybody installed it and had a pleasant experience?
Old 01-25-2013, 01:21 PM
  #34
alpine003
alpine003's Avatar
I would suggest you start a new thread on this.
Old 01-25-2013, 06:15 PM
  #35
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
This loss of oil is generally the only symptom that an engine gives before IMSB failure. Considering this is an 04 and an X51 the equation doesn't sound promising.
We always assume the worst and quantify everything; jumping to conclusions can save a ton of money. If you always expect the worst it's pretty easy to be relieved if its a false alarm.
Old 01-25-2013, 06:49 PM
  #36
pewX3
pewX3's Avatar
Okay, finally was able to take some pictures. Not the best since I didn't have a jack handy (wasn't going to use the spare tire jack with my head under the car trying to take pictures).
Based on posts #8 and #14 from this thread https://rennlist.com/forums/996-foru...your-help.html I'm assuming I have an RMS leak.
Here are some pictures for you guys to chime in on.
Old 01-25-2013, 07:07 PM
  #37
Flat6 Innovations
Former Vendor
The good sign is that oil is clean.. Usually oil dumping from the IMS is nasty and black as it has been trapped there for a long time. Pull it apart an it might only be te RMS, but do the IMS while you are there.
Old 01-25-2013, 08:11 PM
  #38
pewX3
pewX3's Avatar
The original plan was to wait for the clutch to go and do the IMS at the same time.
Maybe I'll try to teach my wife how to drive stick (again ) and have her burn up the clutch some so I don't feel as bad when I have the RMS, IMS, and clutch replaced.
Though she could potentially glaze the flywheel which would cost more money.
Actually looking at the pictures closer, perhaps there was a slow weep going on already. The area looks a bit dirty/crusty.
Old 01-26-2013, 12:50 AM
  #39
fasteddie99
fasteddie99's Avatar
Listen to Jake, pew. He kinda knows his stuff...
Old 01-26-2013, 01:23 AM
  #40
Flat6 Innovations
Former Vendor
If it looks a bit crusty this may be further along than you think, whether its RMS or IMS.
Cut that bearing apart when it comes out and post what you find.
Old 01-26-2013, 02:24 AM
  #41
KrazyK
KrazyK's Avatar
Pew, thats obviously been leaking for awhile. Go ahead and pull the trans then post some more pics. Please?
Old 01-26-2013, 07:20 AM
  #42
DreamCarrera
DreamCarrera's Avatar
Originally Posted by fasteddie99
pew
Originally Posted by KrazyK
Pew
Do you guys receive daily or weekly talking points from JR???
Hint: Put the memos into your own words...at least make it seem genuine.
Old 01-26-2013, 06:37 PM
  #43
fasteddie99
^^Someone needs to get a life ^^
Old 01-26-2013, 09:12 PM
  #44
KrazyK
KrazyK's Avatar
DC is pretty brutal sometimes but I think hes joking.
Old 01-27-2013, 01:35 AM
  #45
DreamCarrera
WOW, a bit sensitive aren't we...what's up with the personal attack bull$hit??? I love keyboard warriors. Apparently, someone needs to learn to take a joke.
Quick Reply: Sudden RMS leaking/weeping ... I think.. :(
