Urgently need your help!
Hi Everyone! I desperately need your help. I haven't used my car for 2 weeks and when I made a quick inspection under the car, I found some oil on the floor and tried to check where it was coming from. I took a photo and encircled the leak on the floor and where I found traces of oil under the car. Can anyone tell me where or what it could be. Any help would be highly appreciated! Thank you all!
Rear main seal would be my guess....dont go too crazy yet...its rumor that these cars dont like to sit...I had a bit of slight weep when the car wasnt driven for a week.
I dont think thats RMS.... RMS drips right on the main brace (it is directly under where the engine and the tranny meets).... Might be brake fluid from the clutch bleed valve, needs tightening, is you brake fluid low? or even tranny fluid?
But I can be imagining things...
Moved the car and took a closer look. It looks pretty much like oil. Tranny fluid should be like red right? This ones not. It has the viscosity of oil and is a little brownish in color. I don't think it's brake fluid either. If it's not RMS, what do you guys think it is? Am planning on bringing her to an Indy tomorrow called Westwerk in Whittier so that I can have some peace of mind. Thanks for all the help!
Thats not RMS unless the car was sitting down hill. The RMS drip woudl be on the cross member or behind it. See my pix. Thats a tranny leak, Coolent leak maybe.
