Changing out those old motor mounts well worth it
#76
I'm glad I found this thread. I just thought it was a lumpy cam at idle. Easy swap, took about 20 minutes and made a huge difference. Would recommend as a routine maintenance item for anyone purchasing a used 996 without documentation of recent replacement. New mount on the left in the photo.
#77
many people talk about the turbo mounts, it would be nice for someone to post the parts# and DIY
I have purchased the RS motor mount convertion kit from sun coast, it comes with a bunch of screws and no instruction. if someone can point to a DIY that would be cool
I mean the kit comes with like 10 screws I thought there was only 3 on each mount... no ?
#78
Phil,
Info I have. Not sure how recent.
Parts Information: Part Number Description
964 375 043 81 New/Engine mount (item 1)
999 025 091 02 New/12.7 x 45.5 x 5 mm washer (item 3), qty. 2 per side
901 305 311 00 Disc (item 2), former part number still valid
900 082 118 09 M12 x 1.5 x 125 mm hexagon bolt (item 4), former part number still valid
999 084 215 09 M12 x 1.5 fastening nut (item 5), former part number still valid–Always Replace
If performing a first time installation of the new type mount, new 45.5
mm washers (999 025 091 02) should be installed on both sides of the
vehicle (Item 3, formerly 34 mm
#79
1 Post
Appreciative
Thanks forum members !!
Yes, well worth it and very EASY.
I've only had my '03 C4S for a few thousand miles.
I could feel more vibrations in the cabin than I thought I should.
I looked at my exhaust outlets and they looked low, so I figured why not.
I changed out my mounts and took it for a short ride.
The tail pipes are much higher and there feels to be less vibrations.
Also, the car just feels good. Mine is a tiptronic.
