Changing out those old motor mounts well worth it
#47
Edit: yes they are reachable without putting on jack stands. Just need to maneuver a longer socket extension between some things.
#48
I may roll the car onto some 2x4's at the end of my garage entrance - that works for oil changes. Gives me a little extra room without having to jack up the car.
#49
IMHO, you don't even really need to do that. There is more than ample room to get to the bottom bolts, unless you are 6'9" and have long arms and/or your slammed to GT3-RS specs. But it certainly can't hurt if you feel more comfortable that way.
#52
Yes, I agree with Pete, it is easier to SEE what you have to do, if the back is up a bit. Even backing up on to the 2x4s is helpful. I would support the engine at that block that everyone uses to jack it, rather than the oil pan, but I'm **** about that stuff, since I had a cracked oil pan from the PO. Just use the jack to lift the engine like 1/4", thats all. One big 18mm socketed nut (63ft-lb torque) under the car, and 2 -13mm socketed bolts on the engine compartment side (25ft-lb???, better check, not as critical, tho) and the mount just lifts right out. I needed a universal and extensions to easily do the top bolts. Just a 6" extension for the bottom ones makes it easier. Do one at a time, and engine can't shift. Fast and easy, like they said.
#54
Either way your car should ride better if your old ones were worn out.
#55
Andy, could you measure the new mount height vs your old ones please, as they seem to sag with age.
I plan on doing the DIY semi solid mounts and have purchased off fleabay some old mounts, but I want to make sure I set the height of the mount correctly before I pour in the PU.
#56
#58
Job done! Anyone who has NOT done their mounts should! My car only has 25k miles, but after 12 years, my mounts were tired to say the least. I didn't know what to measure Ross, so I took a shot next to the tape measure.
I took the car out after installing the new mounts:
1) Way smoother motor, less vibration, feels like a different car!
2) Better shifting! Clutch engages much smoother, with less chatter.
3) Car feels faster, acceleration is smoother!
Best $180 upgrade you can do! Just have a universal drive head, and a 6" extension, to reach the 18mm bolt (NOT 17mm Perry) between the exhaust pipes, etc. You also need the universal drive to reach the driver side top rear 13mm bolt.
#59
Hey I have bought the RS mount kit form suncoast but I have many screws in there, can anybody explain to me what they are for ?
I thought there would be for each mount:
- 1 screw going into the middle of the mount toward the motor support
- 2 screws going on the mount side to fix it to the chassis
But in that kit, it seems I have double of what I need. Some look silver, the other set look more like nickel/gold.
I wonder if there is a "choice" to be made or something
help
help
