NAME that problem: Video of strange oil pressure gauge behavior
See attached video.
Any thoughts?
possibilities:
1. Bad oil pressure relief valve
2. Bad oil pressure sensor
3. Bad ground
4. Bad connectors to oil pressure sensor
Anything else?
Any thoughts?
possibilities:
3. Bad ground
Anything else?
Rat Balls
I am the last person to give mechanical advice, but I did notice that your rpm's were low (well under 2k for much of the video. Looked like when you got over 3k the oil pressure seemed normal. ?
You are way too low with your revs. Keep it at 2500 upwards at all time and the oil pressure will behave itself. You are going to **** that engine up driving like that. The higher the revs, the higher and more steady the oil pressure becomes especially as the engine reaches its higher temps. What's that about 'drive it like you stole it'? Not in your case but at least keep the engine reving higher and use your lower gears. There is no correct time to try and save gas in these cars. Hey thats my speel on the matter like it or lump it. Oh I just saw that Gonzo noticed the same thing..... Good on you Gonzo
This has nothing to do with "low revs" good grief - this is about an erratic bouncing oil pressure gauge - and I'm purposely going slow at low revs to illustrate the large swings in oil pressure readings on the gauge.
And if you bothered to see the video I'm already at engine temp.
Thanks - another sign of the sender going bad is that with the key in on position without engine running the oil pressure gauge reads 0.5bar - it should read zero right?
I saw your video and thats why I gave my opinion. I watched it again in case I missed something.. Nope..Have it your way and change the oil pressure sending unit or at least check the connections and good luck. I cant see that changing driving habits though. 35mph in 5th gear DUH. Thats not normal driving so why would you drive that way to show us a video? Beats me.
Driving 35 mph in 5th gear is (unfortunately) pretty standard in a Tip car. Don't blame the driver, it's just the way things are.
oh its not a manual gear change car and more like an automatic. I didnt realize that. I retract my message and sorry for upsetting you.
Note to self... Never buy a tiptronic car.
