996 Forum 1999-2005
Bilstein PSS9 install question... I'm STUCK, swaybar end link?
Old 07-28-2012, 06:54 PM
Heima996C4S
Heima996C4S's Avatar
Default Bilstein PSS9 install question... I'm STUCK, swaybar end link?
The sway bar end links are bolted to the strut assembly in stock form... where am I supposed to bolt it onto on the PSS9's, I,m confused... car is disaasembled. what to do?
Old 07-28-2012, 07:18 PM
Sneaky Pete
Sneaky Pete's Avatar
Front? Rear? Both? Can you post pictures?
Old 07-28-2012, 08:21 PM
Heima996C4S
In the front, it appears there is no place on the coilovers to bolt on the sway bar end link...
Old 07-28-2012, 08:50 PM
Jackstand Louie
Jackstand Louie's Avatar
sounds like you're trying to put the rear strut on the front....or you've got the wrong model. Post pics of the whole set. Fronts have a flange tab for the drop link, rears have a cup at the bottom and eyelet for bolting to the control arm...see attached. The front is uninstalled, the rear is installed with drop link at bottom.
Old 07-28-2012, 09:02 PM
Jackstand Louie
oops...I got that wrong...I was thinking regular Bilsteins
Old 07-28-2012, 09:21 PM
The DareDevil
The DareDevil's Avatar
It's bolted in the exact same spot.
Old 07-28-2012, 09:41 PM
Heima996C4S
Here ya go... as you can see the sway bar end link is bolted to the strut, but on the coilover itself, there is no place to bolt the sway bar end link on... what am I missing here?
Old 07-28-2012, 09:54 PM
Sneaky Pete
Do you need to re-use the alum carrier from the existing? Kinda looks that way.
Old 07-28-2012, 09:58 PM
Dharn55
Dharn55's Avatar
My PSS10 came with new links for the front. I thought PSS9 also had them.
Old 07-28-2012, 11:52 PM
Heima996C4S
something is definetly missing....
Old 07-29-2012, 08:28 AM
perryinva
perryinva's Avatar
That is not the actual strut it's bolted to, but the lower spring perch. Can't use the stock link I guess.
Old 07-29-2012, 04:32 PM
Heima996C4S
I figured out thru a bit more internet research that I need shorter sway bar end links for the front, the stock ones are to long to reach the new mounting point on the Pss9's. So back to Bilstein I go... thanks guys.
Old 07-29-2012, 04:38 PM
Dharn55
Dharn55's Avatar
Where did you get thr PSS9? They should have come with front links
Old 07-29-2012, 06:49 PM
Heima996C4S
bought em used...
Old 07-29-2012, 11:25 PM
Dharn55
Dharn55's Avatar
You might check for sources for adjustable links from aftermarket suppliers. Or contact the seller to see if they have the Bilstein links. I still have my old setup and could compare the size of the links.
Quick Reply: Bilstein PSS9 install question... I'm STUCK, swaybar end link?
