Cabrio Top & Window Issue - Window not moving out of the way to close and seal
Just noticed today that the drivers side window is no longer moving down automatically when I open or close the door with the top up. The passenger window still works fine. It seems to also roll up all the way so that when the door is closed (since it does not roll down and then back up) the window ends up on the outside of the top seals. Not good.
Usually, the window moves down about a quarter of an inch to get out of the way when you operate the handle. Not doing that anymore apparently.
Anyone had this issue before?
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
I will check the battery, but as the passenger window works fine, dont think thats it.
Only problem I am having is that the windows is not moving that quarter of an inch when either door handle (interior or exterior) is operated to get out of the way so the door can be opened or closed. Top function (open and closing with full window movement) is fine.
