Trim polishing product recommendation?!?
I'm looking for something to use to polish/restore/get rid of the oxidation on the plastic trim and metal areas at the base of the side mirrors? I've been using alot of Meguiar's products but haven't tried their ultimate black, because it only mentions rubber and plastic. Will it work on the metal too? Or is there something you all would recommend different?
I always wax the rubber trim around all of the windows with Meguires Gold and use "Back to Black" for the area below the wipers and all of the black trim under the front trunk.
A trick for the engime compartment is to get the engine really clean than saturate everything in the engine compartment with Armor All and start the engine. Let it sit there and idle for about 15 minutes and get nice and hot. The Armor All will dry oil free and everything eill look new again.
You can use some liquid polishing compound on that black around the mirrors than finish up with Meguires Gold.
Rocky Mountain High
Back To Black works well, but it takes LOTS of elbow grease...
