front sway bar link problem
Hey all,
I ordered sway bar links from a local shop and when I went to replace them they were different. The ones on my car, the bolts turn 180' pointing opposite direction, the new ones turn 90'. So I thought nothing of it thought I got the wrong ones, returned them and ordered from pelican parts, same problem!
Has anyone seen these links before, they look like this.
Year? Model?
Here are the ones for my 1999 996 C2
http://www.napaonline.com/Catalog/Re...+2062003+27430
Check this out. Look at the very first photo....
http://www.autopartsnetwork.com/shop...ion_Front.html
Looks like 2004...
http://www.napaonline.com/Catalog/Ca...062_0309522774
Looks like 2004...
You are looking for front links, right? The correct part number is 996 343 073 05, unless you have modified suspension components. What part number have you been getting? If you're getting the RWD end links, they have separate part numbers for left and right sides. The AWD end links are the same part number for both sides.
ECS Tuning has them available.
The rear links should be 180º as you describe, for C2 and C4. They are part number 996 333 069 04.
