catalytic converter, lemons to lemon-aid?
No it does not mean that. I am only responding for Cargraphic and AWE products not FabSpeed. And your Indy shop is correct.. There is an ~8 week wait for AWE as they are made to order.
dumb question, but is running around on a bad cat with the check engine light on for 8 weeks bad for any other part of the car?
You sure the cat is the issue and not your secondary O2s?
Headers, cats and Fabspeed mufflers, sounds great to me. I was surprised how much the tone changed considering that I was already running headers and their mufflers. It is difficult to describe sound and I will call it metallic. It is also louder as soon as you are off idle.
I'm on the fence, a tech I like at my dealer said Fab speed all the way. Meanwhile a good indy shop said AWE is the only way to go.
Are these 200 cell cats guaranteed not to burn out at the track? Some tracks have sound restrictions and well, I think the 200 cell cats and sport exhausts will be too loud
Used ones are probably worth a bunch. They contain platinum, which is going for ~$1400/oz.
Are there any aftermarket cats that will pass smog in California? My left cat is going out too (probably will get some more life out of it but starting to rattle).
I was worried about my car passing the sniffer test here in Ohio. I have Switzer exhaust and hi flow cats on my TT. The kid took a mirror and ran it under the drivers door looking for the cat and inspecting the exhaust. It passed with flying colors. I'm sure it would've passed even if he would have known where the exhaust was located. I didn't have the heart to tell him he was no where near the engine or exhaust. Even though I really wanted to ask him how he liked the exhaust.
i was all about replacing the cats before learning of CA and the great state-evil empire's BS not allowing anything not having a C.A.R.B. stamp on it. (which no after market company is doing that i can find) i have seen several cats, left & right OEM on EBAY for 2-$300 a piece that were for a 996. That fabspeed x-pipe is hot, too bad i can't use it. I found another x-pipe made in Germany that was supposedly 200 cells instead of the 300/400 cells in the stock for $1k, same BS...can't use it either. Keep looking u will find different cats. good luck!
Also I wouldn't worry at all about getting caught with high flow cats or even test pipes after the fact. Cops will never know what kind of cats you have, and even if you have test pipes our 996's aren't that loud compared to other cars. I run catless with a fabspeed supercup exhaust and it's waaaaay quieter than my NSX and viper were without cats.
For the OP who is in Seattle, they only have state run smog centers, so there is no bending of the rules, but I believe they will let you run with high flow cats so there is no need to go with oem.....
