New camshafts, exhaust and chip
Hello
I found some "sport" cam shafts at a dealer for around 2000 EUR. I was thinking, how many hp can I gain from replacing the cam shafts, the exhaust and "the chip"? What would be a reasonable power gain?
I sounds like it would give a good bang for the buck, doesn't it?
I have a 996 C2 2002.
Robert
Robert
Hello
Robert
Robert
I don't know about Porsche engines but in my day working on Chevy's & Ford's adding just a cam would often result in worse performance unless you opened up exhaust, intake and most times had head / valve work done.
Robert
Hello
Robert
Robert
It has been a while since I did any cam swaps but before I did any I would read up on all the various camshafts offered and compare the dyno charts to get a feel as to what I was getting and getting into. This was before the 'net so I would consume any car mag that had a review of the cam or sometimes several of the aftermarket cams being offered.
Often to get full benefit of the new cam additional changes to the engine were needed: improved intake and exhaust to name two.
And in some cases the new cam or aftermarket cam was crap.
In one case I installed an aftermarket cam (name brand too) and some time later -- I do not recall the miles now the engine had covered but the miles were way past the break-in miles -- I received an offer from someone (a car salesman believe it or not) offering to buy the car, making an offer that I could not refuse.
The deal was done and the new owner when I ran into him sometime after was quite happy with the car. But he added that he found the aftermarket cam had a flat lobe. I was thinking oh oh here comes the hit for some kind of warranty when he surprised me and said he already fixed the engine by just installing a factory camshaft. Everything else was just fine and he reported the engine perked right up and he was quite happy with its performance. (The afermarket cam probably had a bad heat treatment which is not uncommon I read, even today.)
My advice is unless you know what you are getting yourself into you are better off sticking with stock parts in this case the stock cams.
Sincerely,
Macster.
