cam timing
cam timing
after info regarding cam timing. had heads skimmed and new gaskets. marked cams up prior to removal and refiited to marks at tdc but is running like a dumper truck. set up with info according to other tech data, exhuast cam vertical etc. any help much appreciated.
98 3.4 narrow body, thanks for quick reply and interest. new to forum and new porsche owner. hoping to carry out work myself, allready done clutch, front discs and pads, rear pads, fan resistors and head gaskets.
What are the cam readings according to durametric? If the heads were off, just marking and setting to previous marks could make the cam timing off.
For a great write up on how to set cam timing by only pinning the crank with the motor in the car look here
http://986forum.com/forums/performan...iming-m96.html
replaced gaskets due to coolant loss and massive pressurisation of coolant system. san rensho thanks for link, i have vario cam, is timing still same basic set up or do i need more info. and no idea what durametrics even mean or do ?
Search the forum for more info!
Former Vendor
Explain your cam timing regimen. Did you use any special tools?
