Which wavetrac diff for g96.00??
Looking at their website they list 2 diffs,
*G50: 911 1987-88, 930 5spd 1989>, 964, *********993, 968
*996: GT2, GT3, turbo 6MT rear
40.309.160WK
$1,395.00
And
*996: 1998-2005 6MT (excl C4, GT, turbo)
*986: Boxster S 3.2L 6MT
40.309.165WK
$1,395.00
So which one would be better? The vehicle has no traction control and small tires.
40.309.160WK
$1,395.00
And
40.309.165WK
$1,395.00
Just call Wavetrack - they are in Sol Cal and they pick up the phone. I love mine in the 993.
Even if they are dimensionally the same, they might have slight differences.
I got the 2nd Wavetrack built for the 993 after my buddy found out the bad way that the 964 g50 version didn't work on the 993 G50. Wavetrack completely rebuilt my friend's 993 G50 Trans for him gratis..... 993 G50 Wavetrack's now have the "Stonehouse" groove around the diameter.
Well called them and was told that both diffs are internally identical, so there must be something different with the actual diff housings. They couldn't give me anymore information as to what the actual differences are between the 2.
the two Wavetracs are almost identical - and obviously will perform identical but the main difference is axle retention
160wk sun gears are designed for bolt in retained drive flange
165wk sun gears are designed for snap ring retained drive flange
So which one is the correct or preffered model for a 996?
EXCEPT that sometimes cars in one of these groups were manufactured with stubb axles normally fitted to the second. Like mine. So I bought the second, and then had to switch to the first :-(
In short, if you can check to make sure you have the type of stubb axles normally fitted to your type of car, do so, then order the diff. (I suppose the flanges referred to ab ove are what I refer to as stubb axles.) If not, order the diff for your kind of car, and I suppose 90-95% of the time you won't have to exchange it.
