996 Forum 1999-2005
3.8 upgrade UPDATE
Old Mar 4, 2012 | 08:00 PM
Paul 996's Avatar
Paul 996
Ltusler,
My old 99 was setup exactly the same way except that is was a standard 3.6. Todd even did the ECU, same rev limiter.
The one/off switch wasn't bad on the street. Mine had a delay from bank 1 to bank2 to soften it. Fun car, miss it.
Originally Posted by ltusler
Engine is a 2002 3.6 upgraded to X51 then upgraded to 3.8 by Flat 6. Its running the cable TB. The VCAM+ is triggered by RPM switches that bypass the ECU. Either full on or off. Its a dedicated track car so inbetween doesnt really matter. Protomotive did the ECU tuning. Rev limiter is at 7500 and its a blast at the track.
Old Mar 4, 2012 | 08:43 PM
ltusler's Avatar
ltusler
Don't want to hijack Carey's thread. Maybe we need a 996 3.8 subgroup?
Carey, keep the RPM's up! I had mine at Road Atlanta after a couple of hundred miles on Jakes dyno and a oil change. Just don't hit the limiter or keep it revved to high for sustained periods. Over 3k track miles on mine and it just keeps getting better.
Old Mar 4, 2012 | 09:05 PM
philooo's Avatar
philooo
Great news !
I can't wait to see the pictures documenting the build !
Can you elaborate about that valve adjustment thing ? I did not know valves had anything that can be adjusted
Old Mar 4, 2012 | 09:22 PM
chsu74's Avatar
chsu74
That sounds sweet Carey. I am in your camp with removing the AWD parts if you won't see wet/snow weather much. You can always retorfit it. The steering is more communicative this way. My TT has its AWD removed and I like it a lot.
Old Mar 4, 2012 | 09:34 PM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
Best thing I have heard all day. :-)
Old Mar 5, 2012 | 02:28 PM
Turkertwo's Avatar
Turkertwo
Great Post! And what a great opportunity the big bore build offers. With every year and mod that passes I can see how I too might end up at Mr. Raby's place. Something to be said for building your own unique Porsche.
Old Mar 5, 2012 | 04:13 PM
Hardback's Avatar
Hardback
Dyno results as promised.
File Type: pdf
Old Mar 5, 2012 | 04:20 PM
Hardback's Avatar
Hardback
Originally Posted by philooo
Great news !
Hey Phil, where have you been mate? When is your next event? I was shooting for Chin on 17th but not sure if Ill be ready so soon. As for the valves, I assume the the valve clearance may need to be checked but maybe not. We can always put them in the valve stretcher if needed...
Seriously, the car is running really strong. I cant wait to really open it up at the track....
Old Mar 5, 2012 | 04:34 PM
dotframe's Avatar
dotframe
so jealous!
Old Mar 6, 2012 | 03:10 AM
speed rII's Avatar
speed rII
Wheel Hp??
So roughly 390 on the flywheel??
Old Mar 6, 2012 | 03:26 AM
pete95zhn's Avatar
pete95zhn
Former Vendor
Would like to chuck the whole intake and go with a high butterfly, but thats another whole can of worms.
Jenvey has the kit.
Old Mar 6, 2012 | 11:06 AM
Hardback's Avatar
Hardback
Originally Posted by speed rII
Wheel Hp??
I am not sure how much parasitic loss there is from flywheel to wheels. Maybe someone more knowlegeable will respond...?
Old Mar 6, 2012 | 12:37 PM
logray's Avatar
logray
Something like this ????
Carrera 2= -12%
Carrera 4= -17%
Tiptronic= -2%
So if he decoupled and I'm assuming manual?, 327 works out to 366 at the flywheel.
Old Mar 6, 2012 | 01:25 PM
Hardback's Avatar
Hardback
Thanks Bro. Good info... Yes mechanic decoupled and of course my car is a manual. Have you figured aout the flywheel issue you were troubleshooting?
Old Mar 6, 2012 | 02:00 PM
logray's Avatar
logray
Yep think it's finally sorted, old flywheel was toast, rattling/shuddering... new FW is in and working much better/smoother. It looks like just one more issue to sort out with the idle valve.
