Oil analysis report - high iron, copper, and magnesium. Should I be concerned?
#31
And thats why I am checking out from forum contributions. I see the worst of the worst and nothing comes to us just needing "service work".
#32
You need to check the vacuum readings within the crankcase, it sounds like you have a weak/ failing AOS as this is the first symptom thats usually apparent.
This effects fuel trim values and impacts engine management.
The ONLY copper within these engines is the dermis layer of the rod and main bearings. Iron high followed by copper being high is classic and we know what causes it. Here is a picture from my study that shows this very clearly. The engine studied had 47K miles on it, was one owner, never tracked and always serviced. The classic recipe for unexpected failures. We saved this one and I am testing it after reassembly as we speak.
Thank you Jake!
#34
Thanks for letting us know and glad to hear Jake caught it in time. What were the copper and aluminum levels before the teardown?b TIA
#35
Former Vendor
#36
Originally Posted by KrazyK:10229628
Ahsai, why dont you just pull a sample every 1 or 2K to see whats going on? Did you flush and switch to JG?
#39
Former Vendor
Engine is quiet, smooth and strong so not too concerned for now.
#40
Jake, how much will I save if I rebuild it now as opposed to later when and if it blows up?
#41
Former Vendor
When this happens I do know that the cost of admission increases by around 4-6K since the whole core gets thrown away.
Once wear starts the clearances open, the oil pressure drops (resistance to flow is reduced) and then its a snowball headed to hell. Mike was really, really lucky.
#42
Thats impossible to answer accurately.. BUT right now your situation is just a repair and its elective. At minimum you are saving tow bills and the reality that something always happens when you both don't expect it and when its least convenient.
#43
Former Vendor
No one knows the definition of "rebuild". To me it means sloppy procedures and going back together with marginal components.
We did not rebuild or reconstruct Mike's engine because it just needed a repair and it saved him a ton of money. We replaced a lot of parts while we were in there..
Mike's car had less than 50k miles so it didn't need everything that we do. We saved him a ton of cash.
Considering what we see, just receiving an engine that's able to run under its own power when it arrives here is a special occurrence. Dealing with something before it breaks is a privilege. We are proficient enough to tear the entire engine down, repair it and put it all back together and test it inside of one week. No one else you'll talk to will give you this option, because they will lose tons of money doing the work, because they lack capability and proficiency at this level.
#44
OK.... just to get this straight.
A perfectly running engine with moderately elevated copper values reported on a mail-in oil analysis is doomed... Just waiting for the con-rods to come crashing through the engine block.
DSC800 (02-28-2021)
#45
Former Vendor
Mike had no symptoms at all other than his UOA and then when the car arrived here we did more UOA (wear metals were up 12% even with only 500 mi on the oil) and a visual inspection of the oil sump and filter that did not yield any findings. We worked on his car off and on for a month before we made a hypothesis and started taking it apart. The root of his evil started with camshaft lobe wear that then spread through the engine.
