Highest Milage and What Oil are you using?
01-17-2012, 12:26 PM
RL Community TeamRennlist Member
119K, 0w40 M1, 5k intervals.
01-17-2012, 01:56 PM
Used liqui-moly 5w-40 on my last oil change. Pelican parts 5 liter jug.
It's $36 per jug.
Car runs fine. No hiccups. Will have it blackstoned in around 5k miles. See what happens.
Btw car has 23k original miles. MY2001 C4 coupe Tip
01-17-2012, 03:21 PM
I like to read about 100K+ miles with original engines in the 996. Post some more!
01-17-2012, 05:40 PM
118k - M1 0-40. ~5-7k. DD. When I opened the engine @ 100k it looked brand new. When I change the oil it still looks golden. Will do oil test on next change.
01-17-2012, 07:44 PM
Quote:
Originally Posted by
Orient Express
For this car 15K or 2 years which ever comes first. Oil analysis after every change. Never had a problem. Oil had 60% of its additives left at every drain.
3K oil changes are an urban myth.
not on our Saab, if you go over 3-5k the engine will sludge due to an inherent design flaw
01-17-2012, 07:47 PM
100k and whatever I can find. I seriously doubt it matters as much as the pundits would have you believe.
01-17-2012, 08:28 PM
7th Gear
DarkSideEwok
It's $36 per jug.
wow, thats really low miles!!!!
01-17-2012, 09:20 PM
AddictRennlist Member
113k miles, use 0w40 Mobil 1 every 5k miles.
Actually it's even less than that when I DE the car as I will change the oil after each event. Might be overkill but I just feel more comfortable removing the crap that might end up in the engine after tracking it.
01-18-2012, 10:04 PM
117K miles, original engine...0-40 Mobil1
Sweet as can bee
01-19-2012, 12:09 AM
7th Gear
Well so far, the M1 0w-40 seems to have proven itself worthy for our babies. Anyone else out there beat the 157k mark yet? Please post. Thank you.
01-19-2012, 03:40 PM
96k miles
Mobil 1 5w40 (Turbo Diesel Truck)
runs good.
01-19-2012, 08:00 PM
I use a cocktail
of :
Mobil 1 High Mileage 10W-40 and Mobil 1 5W-40 (Turbo Diesel truck) every 5K miles.......60K miles.................
01-19-2012, 10:07 PM
pesuazo
I use a cocktail
of :
What is the ratio?
01-20-2012, 05:57 PM
1 Jug (4 quarts) of 5W-40 turbo diesel; 1 Jug (5 quarts) of 10W-40 High Mileage.....usually there is one more quart of 10W-40 (total 10 quarts)
01-20-2012, 06:46 PM
135K miles on a 99C4, original engine, had it since 18K in 04 and I never paid any attention to what kind of oil goes in. The invoices from my Indy says Mobil 1.
1 ,
10w ,
10w40 ,
2003 ,
40 ,
993 ,
996 ,
c4s ,
changes ,
high ,
kind ,
mileage ,
mobil ,
mobil1 ,
oil ,
pelican
