996 Forum 1999-2005
Help Me ID this Engine Squeal - SOLVED
Old 12-20-2011, 02:17 PM
  #31
Barn996
Barn996's Avatar
Are you saying the serpentine belt was hard to install, was it the right one? When I did my replacement, it was very easy to do. Glad your Porsche is up and running again.
Old 12-20-2011, 02:31 PM
  #32
frisbee91
frisbee91's Avatar
Yeah, the serpentine belt (synchrous belt?) was very difficult to install. I double-checked the part number printed on the belt. It was a Porsche factory part, 996-102-151-66 from Suncoast in Florida. I got it on there, but boy did it put up a fight. Seemed just a tiny bit too short.
Old 12-20-2011, 02:45 PM
  #33
gota911
Newbies Hospitality Director
gota911's Avatar
Frisbee,
Awesome! I am glad the broken bolt came out so easily. Probably a 1 in 20 chance wt would come out that easy. You should have played the lottery that day!
About the serpentine belt.... now where did I put that "belt stretcher?"
Old 06-01-2020, 12:14 PM
  #34
ArtinNC
ArtinNC's Avatar
Hi All
Need help with my 2000 996 pulley noise.. I have attached 2 videos, one with the drive belt off and one with engine running.
https://youtu.be/8v6BZHALjr8
Old 06-01-2020, 12:40 PM
  #35
DBJoe996
DBJoe996's Avatar
Received 1,170 Likes on 749 Posts
Reattach the belt. Run the engine. Use a mechanics stethoscope, or a long screwdriver and put it next to your ear. Then touch a point nearby each pulley. From the looks of the video (second one) it seems almost every pulley you spun had some play or binding. I think the alternator sounds the worst.
Old 06-01-2020, 12:48 PM
  #36
ArtinNC
ArtinNC's Avatar
Thanks.... I order a mechanics stethoscope today should be here tomorrow. The lower idle pulley sound the worst. Is the A/C pulley wheel supposed to be that loose?
Old 06-01-2020, 03:23 PM
  #37
frisbee91
frisbee91's Avatar
You could also try the cheap stethoscope method:
Get a LONG screwdriver. Grasp the handle very firmly, with your thumb protruding. With the engine running, CAREFULLY place the tip of the screwdriver on a stationary surface very close to the offending bearing (i.e. the alternator). Now, stick your thumb in your ear. The sound conducts right up the screwdriver. and can help pinpoint bearing issues.
Quick Reply: Help Me ID this Engine Squeal - SOLVED
