996 Forum 1999-2005
fail safe question
Old 11-14-2011, 09:43 AM
trendy996
trendy996's Avatar
Default fail safe question
For a 99 is there a fail safe mode to not allow the engine to start?
Old 11-14-2011, 09:51 AM
fpb111
fpb111's Avatar
Yes, immobilizer in the security system.
Old 11-14-2011, 10:08 AM
ivangene
Parts Specialist
ivangene's Avatar
clutch switch
Old 11-14-2011, 10:23 AM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
IMS failure,
Old 11-14-2011, 10:25 AM
ivangene
Parts Specialist
ivangene's Avatar
that would just be FAIL
Old 11-14-2011, 10:33 AM
trendy996
trendy996's Avatar
Ok so there isn't a engine code that will not allow the engine to turn over? I don't consider an immob a engine code.
Thanks guys
Old 11-14-2011, 10:36 AM
C4CRNA
C4CRNA's Avatar
I think you need to tell us more.
Old 11-14-2011, 10:42 AM
ivangene
Parts Specialist
ivangene's Avatar
this is fun
Old 11-14-2011, 10:46 AM
Marc Gelefsky
Super Moderator
Thanks guys
Immobilizer would not throw and engine code but it will throw a code if it has a fault. are you using something to scan the car?
Old 11-14-2011, 11:05 AM
redridge
redridge's Avatar
dead battery? .....
there is a mode where the car thinks its been in an accident and will shut the fuel pump off.
Old 11-14-2011, 11:14 AM
trendy996
trendy996's Avatar
redridge this is what its behavior is.
There was a clamp that wasn't seated right on a coolant hose right under the p/s and engine harness connection lines. The hose popped open but not off. When it popped the engine immediatly shut off. It then acted as if the battery were dead. The voltage isn't even registering 12v.
Old 11-14-2011, 11:15 AM
trendy996
trendy996's Avatar
I tried jumping it and still got the same behavior
Old 11-14-2011, 02:35 PM
C4CRNA
C4CRNA's Avatar
Jumping it from the battery, or the engine compartment?
There is a big ground wire from the P/S side that degrades overtime
Could be your problem in the MY99
Old 11-14-2011, 02:43 PM
targa996
targa996's Avatar
DME fuse ?
Old 11-14-2011, 02:49 PM
Macster
Macster's Avatar
Originally Posted by redridge
dead battery? .....
Regarding the fuel pump shut off... based on my experience there may be a shut off in the case of an accident, but after my Cayman S was hit (and declared a total loss -- impact sufficiently violent to cause both air bags to deploy) when I was at the body shop talking things over with body shop owner his helper went out and started the engine to move the car out of the way of an incoming delivery. I was surprised that the engine started.
Sincerely,
Macster.
Quick Reply: fail safe question
