Garage 101: Getting my 996 up on 4 jack stands?
Okay, basic question I know, but what's the best technique to get the car up onto 4 stands?
What order, procedure is best/safest?
For example, should I bring the rear up first, then the front? Should I jack from the center of the axles/differentials, or bring up each wheel at the jack points toward the side?
TIA for the advice!
Howard
TIA for the advice!
Howard
This has been covered, but here is my method:
1. Jack up one side by the rear jack point (in front of the rear wheel)
2. The entire side of the car will raise up.
3. Place jackstand under FRONT jacking point (behind front wheel)
4. Lower car.
5. Repeat steps 1-4 on the other side of the car.
6. Both front wheels are now off the ground.
7. Jack up the entire rear of the car using center of the structural support located between the rear wheels. See picture. You need an appropriate low-profile jack for this.
8. Place jackstands under both rear jacking points. Lower the car.
4. Lower car.
I have had the car up a couple of times already.
Drive both rear tires over 2x10, jack up rear point, put stand with hockey puck under front jack point, put another jack stand with hockey puck under the end of the rear suspension cross member, lower the jack and do the same on the other side.
Would have preferred to jack the rear center part of suspension cross member and put jack stands under factory rear jack points, but the jack can get that far.
Very cool. Breathtaking price. Sears had something similar years ago, but dropped them (I didn't see them com. Seems like we should see more products like this. Makes absolute sense to be able to lift--then transfer the support to a stand.
So odd that we haven't seen more solutions similar to this. Seems like a lot of opportunity there.
I actually jacked it up correctly and had four stands under the jacking points. When I jacked up the rear to remove the rear stands, the car shifted forward on the front stands. The car slid off of the passenger side stand, and the stand crushed and punctured the AC line. It's something of a Catch 22 because you have nothing to chock with all four wheels in the air. It was actually more about what I used rather than how I did it. I used a set of parts store jackstands which don't really fit the jacking points well. A better alternative would be the expensive-as-hell stands with the flat rubber pads.
