Bilstein sport shocks + stock springs=pain
Hey Guys,
I have a spring related question (i think). I recently had my oem shocks changed out for bilstein sports, the stock springs were re-used. the car is an 03 C4S with the standard US suspension.
I'm finding the ride really rough, though the roads in calgary are to say the least.
I've been hunting around the forums and it seems that the Bilstein sports are the same as the shocks that come of the X74 suspension, however the springs are not the same as the ones on the stock US car. So my question is: are there options in terms of H&R or Eibach or something else that is similar to the X74 spring? i was quoted 1000 bucks US from porscheoemparts to get the x74 springs from Germany.
thanks!
thanks!
I think i'm at a crossroads here, not sure if the H&R springs will solve the ride issue, or if i need to sell these shocks get the ROW030 suspension kit....
Anyone else have thoughts on what springs go best with the bils sport shocks?
I think it is the shocks more than the springs. You replaced touring shocks with sport shpcks They are stiffer Stiffer lower springs will improve the handling, but won't help the ride any and will likely make it... well... stiffer.
You might consider an adjustable suspension like the PSS10. A little more money, but it will get you closer to what you are looking for.
X74 is quite stiff suspension, that I would describe as best used on the track or smooth pavement.
The X74 was on the 40th anniversary cars, try to get a ride in one, it is pretty stiff for sure.
Note to the OP, you might have mis-matched springs and shocks. It may be less expensive to looking for matching springs. I know a couple of people how have gone with the sport shock and H&R or Eibach springs to lower the car. The ride will be firm, but not unpleasantly.
If you bought the Bilstein HD shocks instead of the sports with the stock springs you would be feeling far better and your spine would thank you.
You can buy them for $800 shipped from eshocks.com (no affliation, just great prices)
http://www.eshocks.com/bil_veh.asp?M...=All&SubChar=Q
From the eshocks website:
What is the main difference between the different settings?
Heavy Duty will be somewhat stiffer and give your car a stiffer and more controlled ride. Sport setting shocks are 30% stiffer than Heavy Duty and are usually used with lowering springs for very hard driving and competition. We recommend Heavy Duty shocks for most applications.
Hey Guys, thanks for all the input so far.
I'm at a loss in terms of where to go
1. Get the Eibach springs which are a better 'match' for the shocks.
2. Dump the shocks and get the HDs vs. the sports
3. Bite it and get the PSS10 coilovers
Anyone have a comparo of Bilstein sports/HDs vs the PSS10s?
At least the car is getting stored within the next month and i can wallow over it all winter
You've never really said what you are going for. Restoring the original factory ride, better handling, some combination between the two? There are always going to be trade-offs between ride and handling. These are not luxury touring coupes, although some might argue that point.
Decide what you are trying to accomplish, and then your options will be narrowed.
