my new lift!
Are you mounting the turbo-encabulator that is in the backround?
Better check the sperving bearings seals. If they are leaking you might loose the whole encabulator housing. $$$
Range Master
Pepsie Lite
Pepsie Lite
He will never know what happened.
Oh Beede, I din't know you are from Iowa, too.
That could cause the tremey pipe to blow the diaphragm out, the whole thing will be fogged by a huge cloud of white smoke.
You have to pull one side of the girdle spring housing to get to it. If you don't get it balanced when you reassemble it the whole pseudocylindrical wave form activator will be skewed high.
I think he's good... do you see that he is using a ladder-style jack stand as a safety net in case the saw horse fails? Admittedly, it would be better to use two of them.
