996 Forum 1999-2005
TSB for the positive lead to the starter?
Old 05-22-2011, 08:05 PM
joelpirela
joelpirela's Avatar
Default TSB for the positive lead to the starter?
I'm talking about the big (+) wire that goes from the mid transmission to the starter (and then, to the alternator)... do they have an updated part number to use? or maybe the 997 part? I have trouble with the "hot" starting problem and since I'm selling the car, I wanna take care of this before releasing it to the new owner. Anybody?
thanks in advance!
joel
Old 05-22-2011, 10:35 PM
logray
logray's Avatar
I'm not aware of a hot starting TSB.
However I had the same problem - the car would simply not restart when it was hot (really hot - like 90F or hotter), and it turned out to be a corroded wire (the large lead from the starter, alternator, then connection point to the front of the car).
Here's the thread... (in a nutshell I think it depends on the serial # of your engine as to which part to use).
http://www.renntech.org/forums/topic...ltage-problems
Of course, if you are a member you might post there as there are certainly those that are more knowledgeable than I.
Old 05-23-2011, 08:06 AM
RPMulli
RPMulli's Avatar
are you talking about the wire that goes from the alternator to the starter?
If so.. I just replaced this wire and I have the part # its 996 607 019 01
In my AOS replacement thread I came across a severly corroded wire. https://rennlist.com/forums/996-foru...adventure.html
Old 05-23-2011, 09:03 AM
joelpirela
joelpirela's Avatar
Yes, probably part # 21-22 on the diagram. I just needed to know if there is a new version of the cable...
thanks for the info!
joel
Old 05-23-2011, 09:28 AM
RPMulli
RPMulli's Avatar
If they came out with a new part I'm sure that the # i used you would have been superceded. Mine came straight from the dealer about $65 if i recall. Try giving the dealer a call and ask them to be certain. I know when I called pelican they didn't even have that # loaded.
Old 05-23-2011, 10:53 AM
joelpirela
joelpirela's Avatar
Yep, I will give suncoast a call. My symptoms are the usual. Great and fast start up in the mornings (even when cold), no drop on battery voltage during use but after reaching operating temperatures (180) if I stop the car and try to re-start (like filling gas or drop at the post office really quick) the starter sounds like it has an almost dead battery. If you let the car sit for 2 hours, it will start right up. I have a new battery, new starter and new alternator. cable is my next try.
Old 05-23-2011, 12:07 PM
logray
logray's Avatar
Definitely sounds like that cable or a bad ground strap somewhere. +1 on giving a dealer a call for the exact P/N. There is a link in the thread for renntech where Loren posts the two possible parts from PET IIRC.
Here's the post: http://www.renntech.org/forums/topic...ost__p__176351
Old 05-23-2011, 01:26 PM
joelpirela
joelpirela's Avatar
Will try that. The ground strap was ok with good contacts, so by elimination, this is the next step.
Do you know if the 997 version of this cable is any better and would fit our 996's? I know the 997 has a revised/fatter cable...
joel
Old 05-23-2011, 02:10 PM
logray
logray's Avatar
I dunno about the 997 version sorry. A new cable should last 10+ years, assuming the engine doesn't get washed too many times or it isn't stored outside in a rainforest. If you want to save money, just buy some quality 4 gauge wire and crimp the ends yourself. Use some dielectric grease. Also just because a cable looks OK doesn't mean it isn't shot. Which is what I found (if you read through the RT.org post).
Old 05-23-2011, 04:17 PM
911SLOW
Admin
911SLOW's Avatar
996 607 019 01 and 03 are not superseded.
BTW the ground strap part 996 607 030 00 is used in all 1998-2005 911 carrera models, in 997.1 2005-2008 carrera and in 987 2005-2008 boxster.
Old 05-23-2011, 04:45 PM
joelpirela
joelpirela's Avatar
I wonder was is the difference between 996 607 019 01 and 996 607 019 03...
Old 03-03-2015, 07:46 AM
mattblack
mattblack's Avatar
did you fix this?
I have the same problem over here
https://rennlist.com/forums/911-foru...l#post12082496
Old 03-03-2015, 12:26 PM
mcbit
mcbit's Avatar
If it's a cable, any warm start problem should involve cables from the battery to the starter, the starter itswlf or an earth. Low voltage issues can involve any can include all cables, earth, voltage regulator or alternator.
Old 03-03-2015, 12:33 PM
sjg1138
sjg1138's Avatar
Here is a good related thread:
https://rennlist.com/forums/996-foru...ter-cable.html
Quick Reply: TSB for the positive lead to the starter?
