996 Forum 1999-2005
A/C display
Old May 19, 2011 | 11:00 AM
sassyav8r's Avatar
sassyav8r
2nd Gear
Default A/C display
Has anyone seen this happen to the display before? If so, please tell me what can be done about it. And as always, thanks for all of the great info.
SAS
File Type: jpg
Old May 19, 2011 | 11:05 AM
Marc Gelefsky's Avatar
Marc Gelefsky
Super Moderator
You need to replace or I think there are some firms out there that will fix the LCD display.
I have also seen some DIY repair kits on ebay but I dont know if they work.
Welcome to Rennlist!
Old May 19, 2011 | 11:14 AM
fast996's Avatar
fast996
semi ontopic, does every passenger ask you guys or giggle about the MANUELL ? just wonderin
Old May 19, 2011 | 11:24 AM
insite's Avatar
insite
they call this 'the rising sun' phenomenon. you can buy a replacement LED kit on ebay. you'll have to disassemble the face & solder in the replacement board. it's pretty easy if you've soldered before.
Old May 19, 2011 | 11:26 AM
sassyav8r's Avatar
sassyav8r
2nd Gear
Thanks Marc. I have a warranty and will see if this is covered. I'm not betting on it.
Old May 19, 2011 | 11:30 AM
redridge's Avatar
redridge
+1.... you need one of these.
http://www.dhgate.com/manual-vacuum-...5a8d566e8.html
Old May 19, 2011 | 01:06 PM
frisbee91's Avatar
frisbee91
Mine is doing the same thing, only on the left side. I don't want to replace the whole unit, just the LCD display. Found two threads on the subject, but haven't found where to buy the display. I'd prefer an OEM display versus some Audi part. Anyone know exactly where to get it.
Here are the DIY's I've found. (login required for RennTech)
http://www.renntech.org/forums/tutor...imate-control/
https://rennlist.com/forums/996-foru...lay-issue.html
Old May 19, 2011 | 01:17 PM
frisbee91's Avatar
frisbee91
Okay, a bit of searching on EBay yielded this Kit for $61:
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
I looks like it's an Audi display, so the icons look a bit different. Still looking for an exact match to replace this display. Any ideas?
"Audi-type" Climate Control display repair kit:
File Type: jpg
Old May 19, 2011 | 02:24 PM
CabrioArtie's Avatar
CabrioArtie
This is the company which sells the replacement lcd display, they provide a detailed how-to and it requires no soldering. Actually pretty easy.
http://modulemaster.com/en/services/rebuild_info.php
Old Apr 1, 2012 | 07:06 PM
DaveCarrera4's Avatar
DaveCarrera4
NO SOLDERING REQUIRED. I just replaced the LCD screen in my HVAC unit. Took me about 20 minutes start to finish, including removal and reassembly in the dash. Very easy fix. Was a bit confusing since the picture of the metal cage did not look like mine. The kit was supposed to include the alcohol pads - none included. I skipped that step and it apparently didn't matter. The instructions talk about wearling cotton inspection gloves. I couldn't find any locally so I was just super careful, handling the LCD with the wrapper, washing my hands well first, etc. That didn't seem to matter. I think for $77.50 with shipping 9xauto should have thrown in the little alcohol pads and the cotton gloves. I'm very pleased with the new display - much nicer than the big sunsets I put up with since purchase of the C4S 1.5 years ago.
Old Apr 18, 2014 | 12:45 AM
Miami M3's Avatar
Miami M3
subscribed
got into my car tonight and the LCD looked this this ...
edit (pic too large to attach)
Old Apr 18, 2014 | 01:14 AM
particlewave's Avatar
particlewave
Just to clarify, these kits can be purchased on eBay and do not require soldering.
The more readily available Audi version has slightly different icons and says "Manual" instead of the classic "Manuell"
Old Apr 19, 2014 | 08:44 AM
frisbee91's Avatar
frisbee91
I have an extra one of these Audi hvac displays I'll sell for cheap. Pm me...
Old Apr 19, 2014 | 09:02 AM
frisbee91's Avatar
frisbee91
If you want the original factory look. I'd highly recommend this...
http://shop.914rubber.com/LCD-Produc...m1plqscsfapp06
The guy at 914Rubber.com makes replicas of the original LCD displays. They are perfect, I have one in my car. (which is why I have a spare Audi display)
