Climate Control Display Issue
I'd hope it's just a burp of the chip controlling the LCD and a reset of the computer would fix it. But I doubt its fixable except to replace the LCD. Might check and see if there is a plug in for the LCD instead of it being hardwired to the circuit board. If its a plug try taking the connectors off and replugging them in in case its years of corrosion creeping in.
Oh yah electronics corrosion is not always visible. It can be a film that develops slowing being plled between contacts.
OK...figured. Thanks for the quick replies. There seem to be several up on eBay, but they say they're for a Boxster. Would that fit?
There's a DIY over on Renntech for replacement:
http://www.renntech.org/forums/index...imate-control/
Be aware that depending on what you buy and who from, it may not look OEM when it's done.
Update:
If you want the original factory look. I'd highly recommend this...
http://shop.914rubber.com/LCD-Produc...m1plqscsfapp06
The guy at 914Rubber.com makes replicas of the original LCD displays. They are perfect, I have one in my car.
http://modulemaster.com/rebuilds/sho...imate-porsche/
