996 mk1 bumper cover fit.
I have seen this on many cars and mine is doing it too and it is drving me insane.
The front bumper cover. If you look close it appears the cover is sagging in the front..
PIX ON THE WAY HAD TO MAKE AND EDIT TO POINT IT OUT
here look at this while I edit
here look at this and I see a lot of them like this. I tried to correct and it aint happenin!
Is there a big gap between the bottom of the headlights and bumper? If so I had the same issue. If you take the bumper off, you will see that the bumper will slide into a sleeve. I forgot how I did mine but you can move that sleeve up making it a tighter fit. You will have to move other things to get to it though. Its easier than it looks..... nice hour or so project.
I had the same issue initially and was able to resolve it by changing the order of installation. If you read the installation instructions closely you'll see that they specify attaching all of the vertical screws/attachment points before the horizontal (damn my brain, it might be the opposite). It doesn't seem like a big deal, but it allowed me to bring everything into alignment. Unfortunately I don't have the document at work or I'd post it.
-Shawn
-Shawn
