996 Forum 1999-2005
Using an Oil Extractor
Old 04-19-2011, 01:10 AM
jmyles
jmyles's Avatar
Default Using an Oil Extractor
Has anyone used an oil extractor on a 2001 3.4 996? If so what are you using? When doing oil changes I want to use an extractor to get the majority of the oil out then pull the drain plug and filter.
Old 04-19-2011, 03:43 AM
carcster88
carcster88's Avatar
I tried using a Motive extractor that I used for my BMW on the 996. Did not work that well at all. Just my experience. Also, no way it will hold all the oil.
Old 04-19-2011, 04:53 AM
Millemiglia
Millemiglia's Avatar
It will definitely no work on a drysump engine and I don't think it will be a good idea in the semi drysump of 996/997 engines.
Also, as carcster mentions, a 911 have plenty of oil in its systems....
Old 04-19-2011, 08:59 AM
ivangene
Parts Specialist
ivangene's Avatar
fail
use the big hole at the bottom - its really not that difficult AND if you start sticking junk down the fill tube you could end up with a bigger issue (like a piece missing and you habe to tear into it to go find it)
Old 04-19-2011, 12:20 PM
dallison28
dallison28's Avatar
I have used this one for a few years. It works on quite a few cars.
Sometimes it is a PITA to use since it takes a while to suck out the oil. It does come with two different diameter tubes to fit the diptube.
When removing the tube after pulling it out, you need to make sure you keep a rag handy to catch the dripping oil. You also need to make sure that you empty the oil from the tube or it will spill everywhere.
I have used it to suck out brake and power steering fluid from other cars, so it does have its other uses.
http://www.amazon.com/Tempo-Oil-Boy-.../dp/B0000BYP0L
Old 04-19-2011, 12:25 PM
redridge
redridge's Avatar
not sure why people would want to use an oil extractor? Is it for clean up purpose?..... I guess it would be easier on your back (less painful).....
Old 04-19-2011, 12:31 PM
dallison28
dallison28's Avatar
I don't rememberwhy i got it, but sometimes it's a pain to use.
Old 04-19-2011, 04:31 PM
smackboy1
smackboy1's Avatar
I have a Mityvac oil extractor. I don't know about the 3.4L, but it definitely does NOT work with the 3.6L. I am only able to extract 2 quarts or so out the dip stick tube and can't get the rest of the oil out.
It works great for oil changes on other cars, just not the 996.
Old 04-19-2011, 07:19 PM
Dharn55
Dharn55's Avatar
I am with reridge, why would anyone want to use an extractor? You will still need to take out the drain plug to get all the oil out and it is much easier and faster to just drain in that way.
Old 04-19-2011, 08:10 PM
calbo
calbo's Avatar
Real men don't drink from bar straws.
Old 04-20-2011, 03:33 AM
carcster88
carcster88's Avatar
They do work pretty good on other cars. Worked great on my BMW. Used it during the winter months. Just does not do much on my 996. Only reason I keep it now is just in case there is an overfill....and I don't want to throw it out.
Old 04-20-2011, 11:18 AM
Einsteiger
Einsteiger's Avatar
Extractors have their uses, but there is no substitute for gravity if you really want to get it all out. Pull the plug!
Old 04-20-2011, 11:57 PM
Shark Attack
Shark Attack's Avatar
can you tell us why you want to use one?
I myself dont get it either... The drain plug is so easy to get too...
Old 04-21-2011, 12:03 AM
Ahsai
Ahsai's Avatar
I think the OP gave up.
Old 04-21-2011, 12:18 AM
jmyles
jmyles's Avatar
Ok guys sorry for the slow response! First I want to say thanks for all of the responses and I learned not to waste my money. The reason I was interested in an extractor was to simply remove "most" if not all of the oil from the top then (if need be) pull the plug to get anything remaining (and obviously grab the filter). I will continue with the tried and true process!
Quick Reply: Using an Oil Extractor
