Changing my headlight bulb... ?
I checked the fuses, they're ok. The high beam and blinker works.... I don't understand.
The bulb I took out was definitely burnt although that one was not too easy to get out, I wonder if I may have damaged the connection somehow in the process? The bulb I put back in is as seated as I could possible seat it.. I did not touch the new bulb with my fingers, I used a paper towel to handle it.. I don't know what else to check.
Yes I understand If the whole headlight assembly wasn't seated into the fender... I doubt any of the other lights would work .. right?
Either way... I figured it out! The power wire to the low beam bulb (the one I replaced) got loose in my rigorous attempt (why are they so hard to come out?) to remove the old bulb and wasn't making a proper connection. The 3rd or 4th time, I lost count, that I inspected everything the wire just fell out.. so I shoved it back in and hoped for the best. I assumed it was a failed attempt and that this needed repair but I put the whole thing back in the car anyway and low and behold it works now. It might only be until I hit a big bump and the wire shakes loose again, but we'll see. It felt like it was in there pretty good, I have no idea. But that's the cause anyway. I'm no electrician so I cannot repair this myself, so if it does prove to need repair I may need to find someone to fix it, I'm not sure this is a part that I'm going to be able to just replace.
But I do want to say that I bought the Silverstar Ultra (I don't have xenon, am I the only one?) and they are so much brighter and whiter than the OEM, that I had to replace the other one too to match.
Thanks everyone for all your help and guidance. What I thought was going to be a simple task turned out to be such an ordeal. Geez!
But aside from the aggravation You two BONDED
If the wire gets semi-loose (intermittent contact) it could cause spikes that would pop the bulb again.
FYI just in case fuse list from 2003 cab:
