996 Forum 1999-2005
Would like to connect an ipod and cd changer to a cdr-220
Old 10-02-2014, 06:07 PM
Slinger26
Slinger26's Avatar
Anyone try this? http://pedrosgarage.com/Site_2/TechnoTooth.html
Old 10-02-2014, 08:27 PM
Jlaa
Jlaa's Avatar
The solisto, though replaces the CD changer. The solisto cannot work in parallel with the cd changer. That's what the 9PDT switch does --- allow both to work in parallel.
Old 10-03-2014, 08:35 AM
frisbee91
frisbee91's Avatar
Originally Posted by Jlaa
This is a bit dated now but I solved this recently. I constructed a 9PDT switch which basically switches all 9 pins of the CD changer cable between a CDC-3 changer and a Yatour (which handles iPod, bluetooth, SD, 1/8" audio mini plug).
This is what I did --- start with post 33. Hope this helps.
https://rennlist.com/forums/993-foru...-headunit.html
Just to be clear --- what I stumbled onto was a way fulfill the original poster's request --- connect an iPod and a CD changer to the CDR/CR-220 all at the same time. This solution is different from using an iPod cable from Becker or SW Stereo because using the cable forces an "OR" situation. The 9PDT switch allows for an "AND" situation.
Hey Jlaa, Nice job. I was thinking of doing this, since I didn't want to give up the stock CD changer. This might be a project for me this winter. Thanks for sharing.
Quick Reply: Would like to connect an ipod and cd changer to a cdr-220
