996 Forum 1999-2005
Surface rust on brake hubs
Old Dec 27, 2010 | 05:53 PM
LDunville's Avatar
LDunville
Default Surface rust on brake hubs
I have a (new to me) 02 C2 and I have light surface rust on the brake hubs. It's something that I don't want to paint, but I need to clean and put on something that will seal and prevent oxygen from getting to the metal and rusting again. Obviously it also has to be able to handle the high temp of be brakes.
Any ideas?
Larry
File Type: jpg
Old Dec 27, 2010 | 06:07 PM
Quadcammer's Avatar
Quadcammer
why don't you want to paint it?
A little primer and some matte grey will keep it from rusting but not look obtrusive.
cheapest and easiest solution, imho
Old Dec 27, 2010 | 06:08 PM
LVDell's Avatar
LVDell
Agree with Quad....
search user "gota911" for his DIY on painting them. Fast, easy, and should do the trick just fine.
Old Dec 27, 2010 | 06:15 PM
Pac996's Avatar
Pac996
Maybe a rust remover of a light solution of acid. Then zinc based paint. I'd use a paint that is primarily zinc instead of advertised to contain zinc. With current weather a blow drier, heat gun or just a heated garage would make it an easier job. I wouldn't go after the rust with sand paper. It would cause a loss of pores and roghness for the paint to stick to. I'm not sure if the original is powder coated but that's an option too that some rare cases aren't too $$$$ Just a thought on how to deal with it. I'd first ask the porsche dealers shop in my case since they don't BS me since they have plenty other cars for big bucks jobs.
Old Dec 27, 2010 | 06:31 PM
Ed 40Jahre's Avatar
Ed 40Jahre
light sand to remove existing rust and any dirt. Use blue 3M tape and protect the actual rotor portion of the discs. Then as Pac996 said zinc based paint.
Should look great.
Ed
Old Dec 27, 2010 | 06:35 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Here is a link to the thread I posted a few years back. Page 2 has better pics.
Painting Top Hats (brake rotor hubs)
Old Dec 27, 2010 | 06:51 PM
Pac996's Avatar
Pac996
Wow that looks real nice.
Old Dec 27, 2010 | 08:22 PM
gota911's Avatar
gota911
Thank you!
Old Dec 27, 2010 | 09:20 PM
ivangene's Avatar
ivangene
Parts Specialist
well it's either paint or this stuff
LINKY
which appears to detoxify the oxygen
Old Dec 27, 2010 | 10:04 PM
okbarnett's Avatar
okbarnett
sand it and paint it
Old Dec 29, 2010 | 02:29 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
These things are really easy to paint and will last quite a long time.
Old Dec 29, 2010 | 04:24 AM
100plus's Avatar
100plus
OEM Rotors i have found cost only 50 pounds! U might want to consider to just change them out. Thats what i am gonna do!
Old Dec 29, 2010 | 09:44 AM
gota911's Avatar
gota911
Well, for $3 or $4 and the same amount of time invested as changing the rotors, you could paint them.
Make sure you send me half of the money I just saved you so I can add that to my "Porsche Fund!"
