Chirping Tires...
#31
Scandinavian flick at 70+ will get the tires loose. Turn off PSM.
#32
Where to begin? Traction is what most people want, you do not for some reason.
You do realize the engine is in the back, right? All that weight over the wheels will improve traction.
AWD-will improve traction too
Wide rear tire- again, improved traction
PSM-yep, you guessed it traction!
Not a lot of torque from this motor, especially at the low end.
Finally, your clutch will not grab like that of a muscle car on a dump. It will tend to slip and you will tend to need new one's more often.
