Cabin air filter location
You can glue the nut/rubber part to the body when you replace it.
The fine threads of the screw seem to get corroded and break the nut loose when you unscrew it so the nut keeps turning.Cleaning the threads helps+don't over tighten it.
and since rennlist already have saved you $$$ now get over here
https://rennlist.com/forums/payments.php
and get that membership already!
