996 Forum 1999-2005
Will these fit my 996?
Old 10-15-2010, 11:15 PM
larry47us
larry47us's Avatar
Default Will these fit my 996?
I have an opportunity to buy 2 17" Turbo Twists - T-55's, 7" wide, from a 2001 996. Can anyone confirm that these will fit my 2004 996 Targa?
TIA
larry
Old 10-16-2010, 12:51 AM
redridge
redridge's Avatar
any spec on it? offsets, make, pics? I dont recall seeing TT in 17"....
Old 10-16-2010, 01:31 AM
larry47us
larry47us's Avatar
Here's the description:
Two 17”x7” Turbo Twists wheels from a 2001 996 with 22k miles on them. Great condition with some minor scratches.
Straight and true with no curb rash. No center caps. They are not hollow spokes.
They are ET-55. The price is right, I just need to confirm that they will fit.
larry
Old 10-16-2010, 09:25 AM
fbgh2o
Odd Posts
fbgh2o's Avatar
For the front wheels they will fit.
That is the same width and offset as the stock 17" (PN996 362 124 00)
For my winters, I am running
F 7" x 17" et 55
R 8.5" x 17" et 50
They are the same wheels you are showing.
Old 10-16-2010, 10:49 AM
Airrik
Airrik's Avatar
Those are not True Turbo Twist wheels tt are in 18'' only.
Old 10-16-2010, 10:50 AM
larry47us
larry47us's Avatar
I got a PM from someone with 4 - 17" wheels to sell. He says
I have a set of 17" 996 wheels like the fronts that were pictured. 17x7 fronts and 17 x 9 rears both ET55 they are in pretty good condition, not perfect but straight and look good from 10 feet.
I know you are looking for winter tires so you may or may not want these but they have Sumi HTRZII tires on them that are at least 80% + treadlife.
I really don't need or want the tires. He wants $600 for the 4 wheels, which is about what I'd spend on some aftermarket wheels. These look good in the pix, and come with color or black center caps. Now, they're a half inch wider than yours, and they are both ET55 as opposed to your saying ET50's in the rear. I really don't know what the ET number means, and whether 55 opposed to 50 makes a difference on my car.
Is this still OK, and am I all right with them for my 2004 996?
larry
Old 10-16-2010, 02:57 PM
OZ951
OZ951's Avatar
larry
Yes they will fit front & rear.
Old 10-16-2010, 02:58 PM
OZ951
OZ951's Avatar
That's incorrect. OEM are available in 17" as well.
Old 10-16-2010, 07:43 PM
Airrik
Airrik's Avatar
Yes maybe so but I don't consider those types of wheels true turbo twists...more like just twists lol The wheel I am referring to is optional on the NA 996 and is an 18'' turbo rim from the 996 Turbo.
Old 10-17-2010, 03:11 AM
OZ951
OZ951's Avatar
Sure, I hear what your saying regarding your opinion about the name of the wheel but I could see the OP getting confused by your answer hence I made the clarification. The wheel your referring to is the Turbo II (as per attached pic) rather than the turbo twist.
Old 10-17-2010, 03:59 AM
philooo
philooo's Avatar
BTW, I really like the Turbo II wheels, but every time I see those wheels they have the turbo offset, something like 45 and 55 I think... Did they make a special version for the narrow body with 63 offset ?
I have been looking for a while for those wheels as they are the one my car my originally delivered with but no luck so far
Old 10-17-2010, 04:21 AM
OZ951
OZ951's Avatar
Yes they can be bought (replicas) Porsche shop in the UK has them
http://www.porscheshop.co.uk/acatalo...id_wheels.html
Old 10-17-2010, 09:57 AM
AndyK
AndyK's Avatar
17" twist rims were standard on the 99-01 MY narrow body cars. I use that size for my winter wheels. I believe by '04, 18" rims were standard.
Old 10-17-2010, 11:22 AM
Zookie
Zookie's Avatar
the Wheel Pictured Above IS NOT TURBO TWIST WHEEL... This is what Turbo Twist I looks like http://www.wheelenhancement.com/inde...elDetail&id=39
Wheels pictured above is this http://www.wheelenhancement.com/inde...elDetail&id=35 AKA 17" Carrera Wheel
But yes they will fit your 04 Targa 55ET front and 50ET Rear but $600 WITHOUT tires is way to much, they sell for $200-$400, If they were Actual Turbo Twist then $500 would be a good Deal
Old 10-17-2010, 02:15 PM
RF5BPilot
RF5BPilot's Avatar
All this talk is premature. All fitment questions have to go through Ed.
Quick Reply: Will these fit my 996?
