P0491 and PO492 - **SOLVED!**
No, 14 is the pressure supply line that feeds the motor from the sai pump. #28 is the vac line. Its sold in 1 meter sections from porsche. It goes from the accumulator (#6) to the change over valve(#18) to the valve to allow the sai to enter the motor.
All of these parts must work, be in tack or be connected for air to get from the pump into the motor. Its an overly complicated system.
Basically an electrical signal trips the change over valve to open, the vacuum then opens the sai air valve to allow pressurize air to flow into the motor.
If the hose before the change over valve is broken u will see it in the fuel curves, idle performance and during a smoke test. If after the c/o valve it will only leak when the sai is called to run.
In addition to the hose the c/o valve and the sai air valve can both fail but the can be bench tested.
