V1 Hardwire Question...Best/Easiest Place To Hardwire?
Hi all,
I've spent the morning combing through all the v1 hardwire threads and I had a couplr of questions.
Can you hardwire to the dome light? If so, can you do it if you DO NOT have the self-dimming mirror?
If not, what's the best place?
Also, why do many mount their v1 on the passenger side? I've never seen this before and I was wondering if it was based off the hardwire location or if there was another reason.
Thanks in advance!
Thanks in advance!
I used the phone power plug under the radio. I used a credit card to tuck the cable in along the windshield. Went under the dash. Then you pull off the sides by the radio. You should see a little 4 wire plug that is just hanging there. Brown wire is ground then the other two wire are power all the time and power when the ignition is on.
2nd pic shows the 4 wire plug you are after.
https://rennlist.com/forums/996-foru...r23-notes.html
I put mine on the passenger side because I also use the same power source for my track data box (which I want to be out of the way). Others have the V1 concealed display unit, so where you put the V1 isn't as relevant.
-td
-td
Dome light is the easiest (the auto dimming doesn't matter). Just get yourself a wire tap from your local auto parts store and tap the 12v line going to your dome lights.
I mount mine in the middle of the windshield, just below the rearview mirror.
Shawn
Shawn
Great to hear. I have the V1 hardwire kit, that should have everything I need, correct?
1 Post
Use the auto dimming light. The unit will power off after 10 minutes and will come back on with the unlock function of the keyfob. I used a blendmount to mount my beltronics to the mirror mount. This was a slick setup. Yeah I know, my mirror needs cleaning!
Tony
Tony
1 Post
Tony
I did mine that way and took 30 min tops. They only thing I had to remove was the side panels by the radio. When I take my V1 down I am able to tuck almost all of the cord in the head liner and you never even know there was a radar dectector installed.
