gets me the codes and then I have to figure out what they mean... I think it was about $100.. and so far have used it on all 3 cars with success... It will nto do airbag or stabletrak or ABS
Oh, I bet it will be good for lots of things... for example, if you put the durametric cable under the 356, and if it comes out oily, you have an oil leak.
Not only is it good for diagnostics, but I bet if you're clever, you could also use it to make a replacement fan belt or throttle cable!
