Tire stripped off on Montreal Highway
Sorry to hear of your incident.. but glad to hear of the help you got.
But lets look at the tire. . Completely worn down beyond the wear bar indicators on the "inside" or wear side. Sure, it could have been cut on something (and it wouldn't have taken much) or it just failed due to being worn through, plus the heat/pressure of highways speeds etc. I wouldn't worry about the man. date (only 4 years old).
I would confirm that alignment is within spec and I would take note of how many miles you got on the tire so you won't be caught out again.
As for your spare, I can't recall if these cars come with a air compressor or not.. If NOT, I would recommend checking the spare tire inflation level periodically.. No point in having a spare that's also flat!
I know if was worn, but that happening is still out there... Shouldn't have happened. I'm waiting on the news tires to come in and a full install and alignment will be done for sure. I knew very well how much life/condition they had.
Anyways, old news now...
The tire was not safe to travel on to begin with. You risked it and it failed. Luckily no one was physically hurt and lessons can be learned.
its a challenge on these super wide steamroller tires to check the wear. you can hardly see the inside grooves and that is where it seems 80% of the tire wear occurs.. on the inner 2-3 inches. The outer 7-11inches are just for show!
A friend of mine had a similar failure on his 964Turbo. He was running 285s or 295s and just didn't realize how much abuse that part of the tire received.. not only from rolling in a straight line, but also from cornering forces pulling on that part of the tire/shoulder.
When you go below the wear bars you have 2/32 of rubber left before air loss. If you are waiting until you see 'cords' you are an accident waiting to happen. 125kph?? Your very, very lucky - you could have totaled your car or involved other people.
What do you call 125 in a 100 then? Just saying. I agree with racer - your alignment is off.
Montreal is the last place I would drive on tires in this condition. Hell, Kandahar other then IED's is about par with Montreal roads!
Must of been a defect or I must of hit something very very sharp, but I didn't see anything on the road, nor was I speeding.
ya you guys are right!! i'm not argueing the point here. I agree they should have been changed and I wasn't waiting to see cords either. But the fact that I didn't see any at all made me think it's still not that bad yet. Regardless, I would have changed them this week, which i'm doing now anyways.
Lesson learned, and I have to agree that MTL has the worst roads ever, Ottawa as well !!
